Question about Samsung HP-R4252 42 in. Plasma HDTV
Horizontal lines on Samsung Plasma
I have a Samsung HP-R4252 plasma tv. About 1 year after I purchased it (right after the warranty expired) I got several black horizontal lines on the screen. A few months later the picture went completely out. Audo still works. Any suggestions?
  • 2 more comments
  • jonesy75 Feb 12, 2008
    my samsung plasma has just did exactly the same thing as yours last night no picture but have power+sound.warranty ran out 6months ago , any more info on what the solution to the problem could be. .be gratefull if you could help
  • Anonymous Apr 20, 2008
    I have the same problem,totally black screen,I do have audio.Could this be panel failure or some less expensive part?
  • Anonymous Mar 12, 2014
    horizontal lines on the screen of led samsung tv
  • Anonymous Mar 26, 2014
    My tv has horizontal lines going thru half of my tv. I have tried switching the hdmi ports and cords and I still have the problem. I have a crystal clear picture on one side and the other half is watchable, but distracting. The lines are noticeable regardless of the lighting. I tried resetting the picture mode. I'm not sure what else to try.
    Sergeant:
  • 261 Answers
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
Posted on Feb 06, 2008
I have a Samsung 50 inch 3D Plasma TV (model number PN50C7000YF) that has recently started developing black horizontal lines across the top of the screen all in a 3 inch horizontal area. Every week I get...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Samsung PN50C7000YFXZA PN50C7000 3D Plasma...
The most common cause for the loss of picture is a bad Horizontal Output Transistor (HOT). but I would suggest you get a detailed estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system has failed. There are over 100 components in this section and any one of them, or most of them can be at fault. However, the most common failure is the VOT or vertical output transistor (which is often buried inside a chip).
The repair will cost around $150 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding that is fowling things up). Unplug the power cord; leave it disconnected for 4 hours. That will restore everything to factory defaults when you power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic places to see if there are any cold solder joints or loose wires acting up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair if you don't have any knowledge of repairing it.
Goodluck...
Feb 13, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
I have a samsung HP-R4252 42" Plasma which is over 3 years old and 3/4 of the picture is covered in lines and the color is predominately red, any help?
REPLACED Y BUFFER BOARD
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY LJ92-01203A
Nov 02, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung Plasma TV - picture has 6 sections of horizontal lines
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If no reciept then call 1-800-SAMSUNG.
Sep 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
One black horizonal line 1/8 thick on samsung plasma tv
It depends on color of line.
if the line is black, need to replce PDP module(panel)
But, the line looks like noise, need to change the main board.
Sep 13, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252, white vertical line
Unfortunately you probably have a bad lcd panel. This is caused by the heat of the panel releasing the solder that holds the ribbon cable that supplies the picture information to the panel. A lcd panel is more often than not, more expensive than getting a new tv, also the new tv will come with a warranty. Most of the unit I have had this problem with were uneconomical to repair. Sorry for the bad news, Hope this helps.
Mar 18, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Mar 10, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
1,017 people viewed this question
Henry  Thomas
Henry Thomas
