Question about Sony Handycam CCD-TRV43 Camcorder
Warning indicator C:32:00/C:32:11
When I turn the the recorder on (either on camera or player), the warning indcator C:32:00 (or C:32:11) is on (with beeps). I cannot eject the cassette, and I cannot record or play either. I tried the corrective actions suggested by the manual (p 72), i.e. removing the battery pack and reconnecting the power source. It didn't work. Any suggestions? Thanks!
  • Sutty1 Aug 08, 2008
    Same problem here. please advise. thanks. C
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Posted on Aug 27, 2008
I had the same problem. Error code and beep. Won't function and tape won't eject. Pulled the battery, smack the **** otta the bottom, reinstalled battery, and she fired right up. Funny thing is; I stopped at at small camera repair house. Bunch of Ruskees told me mechanics were out of alinement or the board was fried. Either way, $100 + to repair. THANKS gmr2048!!!!
Posted on Feb 20, 2009
Indeed! I took out the battery, used my palm and pat hard under the camcorder for like 10 times, connect the power line, and the tape got ejected out! Turned out, the tape was kind of stuck to the drum inside. My bad, I had it left there for months. Thanks for the solution!!!
Posted on Jan 01, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Just slapped the hell out of my camcorder (TRV 230) and it came alive. Could someone explain why does it work and what was wrong?? Thanks
Andy
Posted on Mar 15, 2010
Thanks, gmr2048. It worked!!!. It took me many smacks (~10 times) to stop the beeps and to get the tape ejected. Perhaps my smacks were not hard enough (:>).
Posted on Oct 26, 2008
YEAAAAAHHHHH!!!! After just taking the battery out and literally slamming it on the bottom of the kitchen floor 10 times.. Installing the battery and does great.. My little boy thought that I was crazy running through the house jumping up and down, but was seriously thinking that I wouldn't be able to record Christmas for my 2 year old.. Thank God.. My code was a C:32:10 and had a re-attach power supply code as well.. My camera is a sony dcr-280
Posted on Dec 21, 2009
Worked for me too! Thank you! However I tried it several times without taking the battery out. It did not work until I removed the battery. Why is that?
Posted on Sep 04, 2012
Worked for me, too. Banged it 1st time, tape was still jammed. Banged it 2nd time, tape was stilled jammed. Third time was a charm. The tape rewound and I am now diditizing it into my computer.
Posted on Feb 06, 2010
    Problem Solver:
Dis was d best,blive me i left my cam unused for 1 year,took to few service center ,in vain, smacking did wonders
Posted on Jun 04, 2010
It stopped working now it is flashing the word protect what do you do
Unplug the speaker one at a time and see if the warning goes away. This protect warning you see usually indicates a shorted voice coil or speaker wiring.
Feb 23, 2017 | The Audio Players & Recorders
I have a 2005 Ford Focus and the fuel light stays on. It is very dim, even when I shut the car off.
Principles of Operation
NOTE: When installing a new instrument cluster, the new instrument cluster must be configured. Refer to Section 418-01 .
The instrument cluster is a hybrid electronic cluster (HEC) which receives and outputs information using both hardwired circuitry and the controller area network (CAN) communication circuits.
It is very important to understand:
  • where the input originates from.
  • all the information necessary for a feature to operate.
  • which module(s) receive(s) the input or command message.
  • if the module that received the input controls the output of the feature, or if it sends a message over the CAN to another module.
  • which module controls the output of the feature.
The instrument cluster carries out a prove-out when the ignition switch is turned from the OFF to the RUN position to verify the integrity of the warning indicators. The charging system warning indicator, the low oil pressure warning indicator and the malfunction indicator lamp (MIL) illuminate when the key is turned to the ON position, and then turn off when the engine is started. The seat belt warning indicator proves-out for 60 seconds and then turns off, or turns off when the seat belt is fastened. The following indicators prove-out when the key is turned to the ON position:
  • door ajar warning indicator (3 seconds)
  • anti-lock brake system (ABS) warning indicator (3 seconds)
  • O/D OFF indicator (3 seconds)
  • air bag warning indicator (6 seconds)
  • brake warning indicator (3 seconds)
  • shift up indicator (3 seconds)
  • low fuel warning indicator (3 seconds)
  • traction control indicator (3 seconds)
  • check fuel cap indicator (3 seconds)
  • passive anti-theft system (PATS) indicator (3 seconds)
Low Fuel Warning Indicator
The instrument cluster utilizes fuel level data supplied by the hardwired fuel pump module to control the low fuel warning indicator, which illuminates when the fuel drops to a pre-determined level.
Your best bet is to take this to the Ford dealer , unless you have Ford IDS - factory scan tool to diagnose this
Your best bet
Dec 29, 2015 | Ford Cars & Trucks
I have a 2004 Jeep Cherokee Laredo. An indicator (with a symbol of what looks like a radiator) below the low fuel indicator (bottom left had side of the dashboard) lights up and remains on. I have checked...
2005 Instrument cluster layout
1. Speedometer
2. Brake warning light
3. Turn signal indicator light
4. High beam indicator light
5. Malfunction Indicator Light (MIL)
6. Airbag warning light
7. Anti-Lock brake warning light
8. Tachometer
9. Security alarm indicator light
10. Oil pressure warning light
11. Electronic Stability Program (ESP)/
Traction Control System (TCS) indicator light
12. Tire Pressure Monitor warning light (base)
13. Temperature gauge
14. Electronic Vehicle Information Display
15. Tow/Haul indicator light
16. 4WD Low mode indicator light
17. Seat belt reminder light
18. Cruise control indicator light
19. Odometer/Trip Odometer
20. Transmission gear indicator
21. Fuel gauge
22. Electronic Throttle warning light (5.7 Hemi)
23. Front fog light indicator light
24. Voltage warning light
Jun 05, 2011 | 2004 Jeep Grand Cherokee
'02 Rendevous beeping randomly, no lights or trouble indicatiors on. Beeps when parked, beeps while driving, no rhyme or reason apparant. sometimes goes 10 or 15 minutes without beeping, other times beeps...
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the left front speaker. The radio receives audible warning requests via the class 2 serial data line from the IPC or body control module (BCM). If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Is the sound heard different from typical Audible Warnings ?
Fasten Safety Belt Warning
The radio activates the fasten safety belt audible warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, slow rate and duration (5 pulses). The fasten safety belt warning sounds and the fasten safety belt indicator illuminates when the following occurs:
• The ignition switch transitions to ON.
• The inflatable restraint sensing and diagnostic module (SDM) detects that the driver's seat belt is not buckled, signal is low. The IPC receives a class 2 message from the SDM indicating the driver's seat belt status.
If the seat belt is buckled when the ignition is turned on, the chime does not sound. If the seat belt is buckled while the chime is sounding, the chime stops. If the seat belt is unbuckled after the initial transition to ON, the chime does not sound.
Headlamps On Warning
The radio activates the headlamps on warning as requested by the body control module (BCM). The BCM sends a class 2 message to the radio indicating the chime frequency, fast rate and duration, continuous. The headlamps on warning sounds when the following occurs:
• The ignition is OFF.
• The BCM determines that the driver's door is open, signal is low.
• The BCM determines that the headlamp switch is in the park or head position.
Key-In-Ignition Warning
The radio activates the key-in-ignition audible warning as requested by the BCM. The BCM sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The key-in-ignition warning sounds when the following occurs:
• The ignition switch is OFF.
• The body control module (BCM) determines that the driver's door is open, signal is low.
• The BCM determines that the key-in-ignition switch is closed, signal is low.
Turn Signal Reminder
The radio activates the turn signal warning as requested by the IPC. The IPC sends a class 2 message to the radio indicating the chime frequency, medium rate and duration, continuous. The turn signal warning sounds when the following occurs:
• The ignition switch is in the RUN position.
• The turn signal switch is in either turn position, sensing, within 1 second, an open to B+ transition in the turn signal control circuit, left or right turn.
• The vehicle has traveled a distance of 1.2 km (¾ mi) by counting pulses on the vehicle speed input circuit.
The IPC turns OFF the turn signal reminder when either the ignition switch is turned to the OFF position, or the turn signal switch returns to the OFF position, sensing, within 1 second, no transitions from open to B+ in either of the turn signal control circuits, left turn or right turn.
Additional Chimes
The following chimes will turn ON when an associated indicator/message turns ON in the IPC/DIC:
• ABS indicator
• AWD Disable indicator
• Battery/Charge indicator
• Brake indicator
• Change Engine Oil indicator
• Door Ajar indicator
• Hot Coolant Temp indicator
• Low Brake Fluid indicator
• Low Fuel indicator
• Low Oil Level indicator
• Low Oil Pressure indicator
• Low Tire Pressure indicator/reset
• Low Washer Fluid indicator
• MIL (Service Engine Soon) indicator
• Oil Life Reset
• Park Lamp Out indicator
• Rear Hatch Ajar indicator
• Service Traction System indicator
• Service Vehicle Soon indicator
• TRAC OFF indicator
For a description of an indicator refer to Indicator/Warning Message Description and Operation .
For diagnosis of an indicator refer to Symptoms - Instrument Panel, Gages and Console .
Did the Mechanic check for DTC'S - diagnostic trouble codes in the BCM or insturment cluster ? Did you try a Buick dealer ?
Jul 09, 2017 | 2002 Buick Rendezvous
On a 2001 ford taurus what is the exclamatin point on the dash? The light comes on and goes off at times.
Hope this helps.
Item Part Number Description 1 — Instrument cluster 2 — Odometer reset shaft 3 — Air bag warning indicator 4 — RH turn signal indicator 5 — Charging system warning indicator 6 — Tachometer 7 — Low oil pressure warning indicator 8 — Brake system warning indicator 9 — Cruise control indicator 10 — Check fuel cap indicator 11 — Anti-lock brake system (ABS) warning indicator 12 — Check transmission indicator 13 — Odometer 14 — Transmission range selector indicator 15 — Trip odometer 16 — Theft indicator 17 — Low coolant indicator (if equipped) 18 — Safety belt warning indicator 19 — Low fuel warning indicator 20 — Fuel gauge 21 — Malfunction indicator lamp (MIL) 22 — Door ajar warning indicator 23 — Traction control indicator (if equipped) 24 — Engine coolant temperature gauge 25 — High beam indicator 26 — LH turn signal indicator 27 — Speedometer
Jun 05, 2010 | 2001 Ford Taurus
How many indicator lights are there and where are they for 2009 f150 supercrew
Item Part Number Description 1 — Tachometer 2 — LH turn indicator 3 — Oil pressure gauge 4 — Overdrive (O/D) off/tow haul indicator 5 — Engine temperature gauge 6 — Air bag warning indicator 7 — Safety belt warning indicator 8 — Fuel gauge 9 — Tire Pressure Monitoring System (TPMS) warning indicator 10 — Speed control indicator 11 — Transmission temperature gauge 12 — RH turn indicator 13 — Speedometer 14 — Malfunction Indicator Lamp (MIL) 15 — Message center indicator display area 16 — High beam indicator 17 — ABS warning indicator 18 — Brake warning indicator 19 — Message center display area 20 — Anti-theft indicator
Feb 27, 2010 | 2009 Ford F-150
Dew warning on continually
http://www.retrevo.com/s/Panasonic-VM-L450-Camcorders-review-manual/id/209ag215/t/1-2/. here you will find a pdf copy of the owners manual. On page 52 you will find a list of authorized service centers. Try giving them a call and ask for their assistance in fixing the problem with dew indicator.They will be able to help you with this problem. I hope this information will help you fix your problem.
May 25, 2009 | Quasar VM-L450 Camcorder
Warning/error message on lcd
Are you still experiencing your problem? I have friends who work with BenQ and I can chase for you if it is still a problem.
Oct 08, 2008 | BenQ DC3410 Digital Camera
My 7d is stuttering?!
vibrating sounds, flashing shake indicator, shutter won't release...
It's a fault in the camera and has to be repaired at the shop, Sorry, I know it's not the answer you were hoping for, but it's a depressingly common problem on the 5d/7d forums.
Jun 04, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Sony Handycam CCD-TRV43 Camcorder Logo
2,782 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
