Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
LinkSys SPA 2102
I forgot my Admin password, is a way I can retrive? Or is there way I can overlap the older one.
  • Luc Del Jan 09, 2009
    olvide mis usuario y pasword
  • nsaaid Feb 22, 2009
    What is the factory default password?
    Scholar:
  • 133 Answers
Try this out
power on your linksys
then pick up the phone connected to that linksys
no dile tone required
dial ****
when it says configuration menu
type 73738#
if ask for password then nothing can help you buddy
and if it says press 1 to save then press 1 and your device is reset with factory default
Posted on Mar 29, 2008
Wifi networks password
Turn over router and check in the bottom default access IP address and then type that IP address in to your
browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password`
as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you
will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select
WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply
and reboot if prompted.
Mar 03, 2012 | Linksys SPA-2102 NA Analog VoIP Adapter...
HOW CAN CHANGE MODEM PASSWORD
browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you
Good Luck
Oct 21, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
I need to hard rest my Linksys Spa 2102 and it is asking me for a password. How can I get arrond this. The password was set by my previous Viop provider.
dial **** and 73738# and press 1 to confirm the resetting. wait for 1 minute
Whats the provider, sometimes they are provide locked :(
Feb 19, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys spa2102 i forget the password
Okay here is what you need to do.
try username : user
password : 1234
or
dial ****73738#
if it asks for a password use 8995523# or 7756112# or 5465866# or 50274537# or 78196365# (one of these numbers should work for you)
Hang up.
to check your linksys pap2 IP:
Pick up the phone dial ****110# The voice will tell you the current IP address. Write it down. Now you put that IP address in your browser and you should be able to get into your box type
http://192.168.1.103(for example)/admin/advance
Press enter.
Feb 04, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
I forgot my password for my Linksys SPA-2102 phone adapter and router, how can reset it without the old password
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first...
Then turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Dec 20, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
My linksys spa2101 is locked, i dont have the password, what can i do
If you forgot your user and password of router then press RESET button of router for 10 seconds it is in back side of router. Then all settings defaults. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . If you forgott WEP password in wireless security note down the WEP code it is your password to connect wifi.Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Sep 06, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA 2102
To reset your SPA device to the factory default values, follow the steps below:
1. Disconnect the Ethernet cable
2. Access the voice menu (****) and press 73738#.
3. Login with the username "user" when accessing to http://spa-ip-address OR
login with "admin" when accessing http://spa-ip-address/admin/.
NOTE: Resetting your unit will erase all the configuration settings. If your SPA device was provisioned by a service provider, the reset function might be password protected. Contact your service provider.
Apr 21, 2010 | Linksys SPA2102 Router
I just bought a SPA-2102 NA, is it possible for a voip provider to lock me out of my device ?or set a password so i cannot reset the device I paided extra to the the unlocked NA version so that i would be...
Yes - if you set provision enable to "yes" or resync from SIP to yes, they can then set your SPA to download a configuration file with an admin password you don't know.
Seems pretty rude (as in legally actionable) if they have actually done this.
Nov 13, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Password of linksys spa 2102
The Linksys comes with web admin access disabled.
To enable it, pick up phone, dial **** then 723646# , when asked for password, dial 78778839# , when asked for value dial 1# then dial 1 to save.
Then, go to »192.168.0.1/admin/voice/advanced , enter user and password.
If you did a factory reset, you will need to call Linksys technical support.
Nov 09, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
971 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
