Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Ice building up on top of drawer
We kept having puddles on the floor and i realized the door was not shutting properly because ice was building up on the top of the drawer on the white part in front of the seal. now, every morning i have to chip off a large chunk of ice. i can't figure out where the ice is coming from?
  • 236 Answers
Try to defrost the unit until all the ice disappear in the evaporator coil.
Posted on Feb 05, 2008
Water is sitting on top of freezer compartment and leaking out on floor
Make sure that your drawer is aligned properly and that there is no ice build up anywhere. Mine built up some ice in the very back and side somehow, and caused the door not to close tightly which lead to a similar problem. Removing the ice build up cured it.
Jun 13, 2014 | LG LFX25960ST Stainless Steel French Door...
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
I have a Jenn-Air refrigerator, Model JCD2389DE, and in the last two weeks we have noticed water puddling on the floor in front of the "freezer side" door. We thought maybe the water dispenser...
Mine did this a few years ago. I had to call service out to replace the system board. I guess it's a common problem. Something on the board fails and the defrost operation does not work properly, resulting in rapid meltdown of ice build-up and puddles on the floor.
Nov 14, 2010 | Jenn-Air Refrigerators
I have a Kenmore refrigerator side-by-side with water/ice in door. Model number 363.9534783 serial number L431 12755. It is now intermitantly leaking water on the floor. A couple of days could go by with...
1. A door open partially will cause a frost build-up then thaw and run down to the floor. Check all doors for proper closure and educate other users.
2. An issue with an unhappy animal is quite common
3. Door switch intermittently causing a light to stay on ora fan to not run
4 Ice build up around ice door chute .
5. Water dripping into ice tray and overflowing. Replace water valve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 18, 2017 | Kenmore 57029 Side by Side Refrigerator
Ice Maker
sounds like door is misaligned while both doors are closed is the gap even from top to bottom if not than make adjustments top and bottom serews, try to find out whats draging drawers not shutting all the way ect,ect
Apr 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice is forming around the ice maker where the ice dispenses through the opening in the door. I have taken out the ice drawer and washed it so that there is no more ice. I have also eliminated the ice...
Check and make sure that the flap that lets the ice out is shutting properly. When warm air enters the freezer door, it condensates then water freezes forming your ice. If this is your problem, they make a kit that replaces it. Good luck...
Nov 17, 2009 | Refrigerators
Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Feb 08, 2009 | LG LRFC25750 Refrigerator French Door
Check the drain tray under the evaporator its probably froze over causing water to overflow in the freezer
Mar 02, 2018 | LG LRFC25750 Refrigerator French Door
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
135 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
