Question about Panasonic KX-FPG376 Plain Paper Thermal transfer Fax
# of rings before answering
I don't use the fax on this machine and can't get the answering machine to pick up after 4 rings. The Tam/Fax ring shows # of rings at 2 and the
Telephone only ring is set at 4. When I test it by calling it from my cell phone it doesn't pick up for 10 rings even though automatic answer is ON.
    Problem Solver:
  • 19 Answers
Check to make sure you do not have distinctive ring option turned on.
Posted on Feb 08, 2008
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
1. Fax answers on long distant rings. 2/ Can not receive faxs. 3/What does Tam#ID =11 mean?
1.- Distinctive Ring service from your phone company
2.- Cannot receive faxes
3.- Telephone Answering Machine (TAM)
Item 1 check page 31.
Items 2 and 3 check Troubleshooting pages of the Panasonic OPER-MANUAL
Jun 23, 2011 | Panasonic Office Equipment & Supplies
Dx-800 wont work with answering machine. Tried all the fax settings to use with a tam. Tam picks up line then dx-800 drops out everytime.
Set the answering machine to answer on 4 rings and the fax to answer on 6 rings.Do this with answering machine menu.
May 15, 2011 | Panasonic Panafax DX-800 Plain Paper Laser...
1. Machine is on telephone line shared with a 3 handset cordless Uniden system so telephone may be answered around the house. The machine no longer rings when calls come in so we only here the Uniden...
These machines come with several receiving modes that can be programmed ... mostly by design but quite often ... by accident.
I would check the User Manual for Ring Patterns, Silent Reception and Fax Priority.
You can always see or print out the Option Settings of your facsimile. There it will show the exact picture of what the fax must know before answering the incoming call.
Does it have Fax Tone Detection? Is it set for automatic answering? Faxback? Polling?
Maybe a power hickup might have scrambled some of the programmed features?
Obviously nobody in the location monkeyed around with tha fax buttons, right?
By George. Of course not!
Please feel free to contact me anytime.
Feb 14, 2011 | Canon FAXB840 Plain Paper Bubblejet Fax
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
I can't figure out how to set up my fax machine so it won't mess up my phone and answering machine either.
Telephone wire goes to fax, out to answer machine, Important to set fax on answer machine mode and set the ring count to pick up AFTER the telephone answer machine. Set fax ring count to 5 rings, and answering machine to 3 or 4. When some one calls answer machine or you pick up first, then if no one will leave a msg. fax tones are different than voice tones, they are called CNG tones. Most new fax machine will sense this and if a fax will go to fax only. Ring count is the key. Also you could set fax up for maual mode and would not jump to anser machine or fax till you want.....good luck
Aug 28, 2008 | Office Equipment & Supplies
FAX JX500
Mary:
Given that the last question I responded to for you related to a Fax JX200 - and this to a JX500 - I am not certain which model you are actually asking about. The information that follows relates to the JX500. Further, if you need information in this regard on the prior post in order to feel that the previous response was a FixYa level response, please let me know. I responded based on the information you provided...
Based on the fact that you are getting a constant 5-ring situation, it appears that the machine is in TAM (tel-ans mach) mode. The purpose of 5 falls into remote recovery of messages - toll saver results in the phone answering after 2 rings if there are messages to retrieve, and 5 if there are not. This is done to prevent long-distance charges if there are no messages.
Two ways to accomplish an 8-9 ring objective. (1) Place the machine in manual mode, which means answering every call and sending faxes to the machine. Additionally, a "fail-safe" on this mode is that it will switch to TAM/automatically answer (if there is a recorded greeting message) after 15 rings - below. (2) The incoming ring - ring count - can be set (under Fax/Tel Auto) to ring 10 to 60 seconds before the fax picks up. (3) Alternatively, the Incoming Ring ring count can be set to have the fax ring 2 to 30 times, depending on the country specific parameters.
Re TAM: When the fax is set to <MANUAL MODE> and <MAN/AUTO SWITCH> has been set to <OFF>, TAM MODE will be activated if the fax rings 15 times and the call is not answered (only when an outgoing message has been recorded). When the call is disconnected, the fax returns to <MANUAL MODE>.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding your specific needs, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 04, 2008 | Canon FAX-JX200
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Panasonic KX-FPG376 Plain Paper Thermal transfer Fax Logo
131 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
