Question about Samsung CLP-600N Laser Printer
SMPS Fan error
When I try to print, the printer goes through it's initial start up proceedure, that turns quiet and I get this error reading. Any suggestions?
Many thanks
John in Rhode Island
  • 4 Answers
The SMPS Fan Error is caused by slow or no rotation of the SMPS Fan. The firmware solution from Samsung disables monitoring so if the fan stops the printer will keep working. Thankfully, it's not physically hard to fix this issue though and can be done by removing 9 screws and using a little oil.
I've actually posted a step by step guide to fix this here.
Posted on Aug 15, 2008
If the printer runs its adjustment cycle and stops just before printing, it is most likely a problem with a driver. Call Samsung's 800 number. You will need to speak to a Level 2 technician who will send you an e-mail with a zip drive and instructions. One tip: You may have to install it several times before it works. I hope this helps you.
JC
Posted on Feb 28, 2008
I just called Samsung with the same problem..solution unplug printer.
then plug back in. It worked.
Posted on Mar 04, 2008
  • 749 Answers
You cannot fix this one here... it needs a parts replacement inside. The fan that controls the temperature is not working. The printer does not allow overcooking... Take it to a Samsung service center for the repair or to your Samsung dealer to assist you as part of their customer support and services.
Fixya me on this...
Posted on Feb 05, 2008
I know the best way for solving this problem but wat will i get when i give u the points
Posted on Jun 26, 2008
I change the cartridge but it stills display put in cartridge
Hold down the power button. Let the printer shut off. Turn it back on. From Windows Start button, go to Control Panel - Printers & Faxes; right-click on Canon MP390, click on Printing Preferences, open the tab for Maintenance, click Quiet Mode and choose Always Use Quiet Mode. When the error recurs, cancel all pending print jobs: double-click on the printer icon in the tool bar (bottom right corner of monitor) to open the Print Queue, click on the jobs, then press the Delete button on the keypad. After all pending jobs are deleted, power down the printer by holding down its On/Off button. After 2+ minutes, turn it back on & try again. Depending on how frequently you use the printer, you may find it's time for a replacement.
Dec 05, 2012 | Canon MultiPASS MP390 All-In-One InkJet...
Hp colour laserjet 9500hdn has service error 49. FF81
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back.
You can try & initialize the drive first though:
- Turn off printer
- Press & hold [Start] button
- Turn printer on, wait for all 3 LEDs to stay solid then release button
- Press & release [Left] arrow button (should read "Initialize Disks" on display
- Press & release [Select], then wait for printer to warm up
Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
Apr 29, 2012 | HP Color LaserJet 9500HDN Printer
Unable to open printer(read error) this is the error message I have received. I have turned off the printer and the computer but the message is the same. I also deleted the printing job, turned everything...
try to remove printer from add printer wizard, unplug cable and insert, found new hardware must be appear, from that locate driver manually to initialize. restart pc and run test print wizard.
Mar 25, 2010 | Canon I960 InkJet Photo Printer
When it starts up it goes thru the steps then the error light comes on and it will not print. I put in a new ink cartridge and it did not help
The 8 beep error you are getting is a waste ink tank full error. The BJC 85 has a waste ink " tank " that is actually a series of absorbent cotton pads in the bottom of the printer. When these pads fill with ink, the printer is designed to produce that error and stop printing until the pads are replaced.
I can give you a work around to this and get you printing, but you must understand that, because the waste ink absorber is full, ink will eventually start leaking out into the bottom of your printer and either leak out of the printer, or end up shorting out the main circuit board , which is also in the bottom.
Here is the work around that will reset the printer and get you printing again:
1. Shut off the printer and unplug it from the power supply.
2. While holding down BOTH the POWER and RESUME buttons, plug the power supply back in. KEEP HOLDING DOWN the buttons until after the printer does it's initial actuation and then goes quiet again, then let go of the buttons. .
3. With the fingers of one hand Hold down the RESUME and CARTRIDGE buttons and with the other hand hold down the POWER button. Listen for 2 BEEPS. they will not be loud, and one will be longer than the other. When you hear the 2 beeps, let go of all the buttons.
4. Now press the CARTRIDGE button 15 times. You will hear a beep each time it' pressed. Make sure you count the beeps correctly.
5. After you have pressed the cartridge button 15 times, then press the RESUME button. The printer will beep and shut off.
6. Press the POWER button and the printer will power on and be ready to print. At this point, the printer will have been reset to indicate the waste ink is 50% full.
If you make a mistake, you can unplug the prnter and start over from step 1 at any time.
REMEMBER: Your waste ink pads are still FULL. You need to either replace the pads, or replace the printer before to much time goes by. If you see any ink leaking out the bottom of the printer, definitely stop using it.
Mar 13, 2010 | Canon BJC-85 InkJet Printer
When i power on cpu fan start initially and then sop
try to change your fan proccesor or your power supply adapter for your CPU
Mar 12, 2010 | ASUS M2N68-AM SE2 Motherboard
Can print...ink system failure - followed process but it wont wor
release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
CLP-600N: Will not print. Fan error.
Just need to replace the fan, #jc31-00012c
Jul 24, 2009 | Samsung Office Equipment & Supplies
After getting error 79 won't print
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
  • Hope it works for you
Apr 24, 2009 | HP LaserJet 3330 All-In-One Printer
Color Printer fan error
Mar 25, 2008 | Samsung CLP-600N Laser Printer
Smps fan error
Nov 30, 2007 | Samsung CLP-600N Laser Printer
Samsung CLP-600N Laser Printer Logo
492 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
