Question about GE GSS25JEMWW Side by Side
GE Side by Side Not Cooling
My freezer is working fine however the refridgerator is sitting at a warm 50+ degrees. I've had multiple issues with this model - only 5 years old - mostly the ice maker. When I open the freezer and shut the door, I can hear a "gurgle" coming from the rear that I've never heard before.
  • jennwebb Feb 05, 2008
    I'm not sure I understand. My freezer has no ice buildup and I really don't understand your response.
  • spangewiner Aug 09, 2008
    I'm having the same issue with the exception that I do have visible frost buildup in my freezer. Should I still unplug the fridge for 3 hours and try restarting it after that point?
    Master:
  • 619 Answers
Hi , the refrigerator having problem with enfeller fan stuck it needed to defrost manually to drain all ice buildup inlet of refridgerator hole after 3 hour try start refrigerator.
Posted on Feb 05, 2008
  • leo2 Feb 05, 2008
    Hi , I mean the ice is not visible inside the refrigerator , it is cover with plastic wall , the cold air coming fan connot pass to refrigerator .
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Ge Side by Side not cooling
check the freezer panel in the back for frosty ice build-up. is the freezer evaporator fan running?
Aug 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerator won't cool. Freezer works fine!
Pierce, there was a service bullitin put out on this model. TDR-0010A-B. Had to do with normal freezer, warm fresh food compartment. Maytag issued a kit that included a new thermostat and damper assy. to solve this problem. Bullitin came out in 2002. If you are not having a defrost issue and all fans are running normal, I would call Maytag and inquire about the above posted bullitin, It may be covered. Catriver...post back.
Sep 03, 2006 | Maytag MZD2768G Side by Side Refrigerator
GE GSS25JEMWW Side by Side Logo
320 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
