Question about Mustek ScanExpress 1200 Flatbed Scanner
Batch scan / several pages
I don't know how to use the batch scan function. When I click the batch scan button, a new window opens but how can I scan more than one A4 pages, and save it as one JPG file?
  • 749 Answers
You are on the right track... It is normal that for every scan a new window opens... the problem is to put them in one frame...
After your scans... create a new window (let's name it ABC) and set the size that you wanted... if you're done. Go to the 1st scan then select and copy a frame... Now go to ABC frame and paste it, adjust the size to project the accommodation of what is to be placed inside. Go to the 2nd scan then select and copy a frame... Go to ABC frame and paste it, again set the size... Keep doing that to other scanned data and.....
I hope I had Fixya your problem....
Posted on Feb 05, 2008
Can anyone explain how batch file works?
This is kind of tricky not knowing how familiar you are with the commandline, but a batch file simply contains single commands and executes them in order (usually from top to bottom). A batch file (or bash script in Linux) can be very helpful if you have to run certain commands over and over again, so you don't have to write them by hand.
An Example: You want to store your network settings in a text file.
You open the command prompt (WIN+R) and type this line:
mkdir C:\Network
Then you type this line:
ipconfig /all > C:\Network\ipconfig.txt
The first line creates a folder on your C: drive called "Network"
The second line runs the ipconfig command and saves it as a text file in that new folder.
To make a batch file, you open Notepad and insert the two lines. Then save it as "IP.bat" (make sure not to save it as "IP.bat.txt"! This is the most common mistake. If you save a file from Notepad, select "All Files" in the "Save As Type" dialog. Otherwise it will save it as a .txt file and you have to rename it later.)
Now you can double click the batch file and it runs all commands in the file.
You can also see the danger. If you run a batch file and don't know what it really does, it can destroy your whole system. So make sure you understand it and/or get it from a trustworthy source.
A nice example of how complex a batch file can be is here:
AllHelp.bat
Copy the content into a text file, save it as AllHelp.bat, run it and it will create a webpage with all available DOS commands.
Hope this helps - otherwise let me know if you have specific questions.
Enjoy!
Feb 26, 2012 | HEWLETT-PACKARD Computers & Internet
Tip
How to create a batch file on windows xp.
To create a batch file that would be very helpful I suggest downloading notepad++ it's made for programming.First off open up notepad++ and go to
languages and click on batch then type in "@echo off" at the beginning of every batch file you need to type that in.Next type in:
______________________________________________________________
@echo off
echo.
echo What would you like to do today?
echo.
echo 1)Notepad
echo 2)Paint
echo 3)Calculator
echo.
set /p web=Type in Option:
if "%web%"=="1" ("%SystemRoot%\system32\notepad.exe") else (exit)
if "%web%"=="2" ("%SystemRoot%\system32\mspaint.exe") else (exit)
if "%web%"=="3" ("%SystemRoot%\system32\calc.exe") else (exit)
You just created a batch file menu now save this file to the desktop as
"Menu.bat".Now that you have the file saved download this free batch file compiler called "battoexe" so nobody can edit or destroy you batch files.
That's it you have made your first batch file visit my website at www.wix.com/Firestorm002/Batch101.
on Jul 18, 2010 | Computers & Internet
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
when happy with your settings click OK again, then apply.
Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
Hope this helps!
Nov 10, 2010 | Fujitsu fi-5120C
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
Copying to c:\ in vista using batch files..
You need to left click the batch file and "Run as Administrator".
Nov 01, 2009 | Microsoft Windows Vista Ultimate Edition
9080c fails to scan single page; has trouble scanning a batch.
Hi
what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
good luck.
Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Have been given a Lanier015spf photocopier and would like to know how to use the scanner function?
Hi netz:
I found a couple things to help you out. First of all, youre going to need to install the driver (if you didnt get the CD)
If you are using Vista, click here
If you are still using Windows XP, click here
After installing the copier (nice gift, by the way), you can operate the scan function by:
1. On the device's operation panel, press the [Scanner] key.
2. Press [Original Feed Type].
3. Select [Batch] or [SADF].
To scan originals using the exposure glass, select [Batch]. To scan originals using the ADF, select [SADF].
4. Press [OK].
5. Place originals.
6. Press [Start] to scan originals.
7. If [Batch] is selected, place additional originals, and then press [Start].
8. If [SADF] is selected, scanning starts automatically when you place additional originals.
9. Repeat this step until all originals are scanned.
10. After all originals are scanned, press [#].
11. Storing or transmission starts.
If you have any additional questions, dont hesitate to ask. Also, for future reference, here is the manual for your copier.
NOTE: your model number is actually LD015
and most manuals and drivers associated with your product can be used for the LD015f ; LD015spf and vice versa
Hope this helps,
TJ
Dec 15, 2008 | Office Equipment & Supplies
How to edit registry
1) to edit registry go to start / select run and type regedit. from there you are able to edit registry values. BEWARE because editing registry values may make your windows stop working. you should know what you are doing and you are responsible of the cosnequenses 2) a bat file is a batch file. Batch files are files that allow MS-DOS and Microsoft Windows users to create a lists of commands and/or programs to run once the batch file has been executed. 3) create a file called autorun.inf and type inside [autorun] open=file.exe save your file and write it in the cd you want to autorun the file.exe part must be replaced with the executable you want to load when your CD autoruns
Oct 08, 2007 | Microsoft Windows XP Professional With...
Mustek ScanExpress 1200 Flatbed Scanner Logo
112 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Mike
Computer Links
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
