Question about GE 46GW945 46" Rear Projection Television
46 inch rear projection tv bulb replacement model number 46gw944
How do you change the bulbs in my tv? is it something i can do? the picture works but it is gradually going black each day.
  • 61 Answers
The tubes are most likely not the trouble,sounds like you have a bad screen asy part number is 204809,must use the generic,Thomson discontuned this part.
Posted on Mar 05, 2008
2 Suggested Answers
  • 1694 Answers
SOURCE: 46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Posted on Feb 05, 2008
I have a 55" Sony Rear Projection TV and when I turn on he TV I hear the voices but it takes the picture about 30 minutes to come on? The bulb was replaced less than years ago
First is the model listed here does not use a bulb, it has 3 picture tubes. What is actual model number as I think wrong one is listed here.
Dec 20, 2012 | Sony KP-51HW40 51" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Picture is gradually getting darker
It sounds to me like your bulb is going out. You have a rear projection TV, and since so, there is a bulb that shines the image onto your screen. Because of this, you need to replace the bulbs after awhile. Call customer support or look around online for a replacement bulb and directions on how to change it. Very simple, but takes a little time and effort. :D
Mar 20, 2010 | Hitachi 46F510 46" Projection HDTV
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
Philips Projection TV Bulbs need changing
Buy a new television. The "bulbs" are actually small picture tubes, also referred to as CRT's or guns. There are three of them, Red, Green and Blue. The cost for the tubes alone will probably exceed the original purchase price of the television. If the new tubes do not have the lens assembly attached, then you will need to transfer the old ones. This involves draining, cleaning, and refilling the coolant chambers. Once installed in the set, there is a series of mechanical and electrical adjustments required, to get the picture aligned or converged. This procedure is not recommended for the inexperienced. If cost and time are not an issue, then everything can probably be found on the Internet. Simply search the web for your model number. You will need the remainder of the model number first. There are at least eight models starting with 46PP9302. You are missing three additional characters.
Discouraged yet?
Nov 15, 2008 | Philips 46PP9302 46" Rear Projection...
Feb 05, 2008 | Televison & Video
Televison & Video Logo
280 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
