Question about Singer 7436 - INGENUITY
Replacing the bobbin case
Took out the bobbin case to clean a thread jam, and tried to replace it according to manual instruction. The needle thread gets caught and breaks every time. I don't know what I'm doing wrong. Help!
  • 4 more comments
  • gestalt Feb 05, 2008
    Thanks. Just tried it, but no luck. Needle thread seems to be consistently caught on screww in front of bobbin.
    No luck!
  • gestalt Feb 06, 2008
    Abssolutely no help. Didn't change anything.
    This is no help either. The winder isn't the problem.
    Thanks, I'll try it and let you know!
  • gestalt Feb 13, 2008
    Took it to the repair shop. Nothing suggested worked.
    Guru:
  • 1,894 Answers
1) Use a strong polyester type thread, NOT FINE COTTON
2) Use a low tension,nuber 2 for exanple
3) Always check the threading, if in doubt rethread all the way
from the top bottom making sure you pass roun and not
through thr fixed holder spring.
4) Make sure the thread moves freely with the tension disc held
to the right while pulling the thread through the needle
5) Be very careful that the thread is pulled up from the lower
bobbin correctly and check there is no muddle or stray
thread under the cover
6 Dont pull on the fabric (not thick for beginning) - just guide it
Posted on Feb 05, 2008
  • 7 more comments
  • dewan nafees ahmed Feb 05, 2008
    try lubricating parts too.. just give a try
    read this google book
    this page may help you
  • dewan nafees ahmed Feb 06, 2008
    Make sure the bobbin winder has dropped down completely, see if you can see any thread caught under the winder itself, be sure the thread has not gone down the wrong side of the tension disc, that is quite common and providing you have the tensions set properly the machine should not break the thread, at the very worst it could be a timing problem.
    hmm then please rate the solutions and seek help from other experts..
    thank you.
    ya ok. then please rate my solution so that you show that question to other experts.
    thank you
  • dewan nafees ahmed Feb 13, 2008
    what happened???
    oh that is really good decision.. 10 years warranty is really great my friend..
    but what company you are using currently is really a very good one.. it has very good models too.. try its new one.. its really great..
    thanks a lot..
    ooops tat comment was not for you.. ignore it please..
    thanks a lot..
    wish you good luck
  • 749 Answers
Remove the bobbin and drop a little oil in the bobbin holder at the center which you usually insert the bobbin...
Happy Fixya... keep me posted on the result....
  • Rommel Balcita Feb 06, 2008
    ok... I was once asked to determine what was causing that same type of problem... After I lubricated the mechanism inside, it went fine, but I forgot to tell you about the needle. If you can do manual slowly watch the needle as it goes to the hole, needle must be at center... if not, then that causes the thread to break. If it is, then you needed to change the needle....
    Hope this one helps.... Fixya me if it works...
My foot pedal wont move the needle, and my handwheel wont budge. Nothing i can see is causing it to bind. What could be the problem?
it may be cotton threads around the bobbin shaft causing it to jam up
take it to a sewing machine service center and have it serviced
Oct 18, 2015 | Singer 3116 Simple
Thread breaking
Can you please tell me what is the model no. and the brand so that i can help you fix the problem.
Waiting for your reply..
Feb 24, 2008 | Singer CE-200 Quantum Futura Computerized...
How do I reassemble drop-in bobbin case for Brothers XL 2600 free arm?
Do you have some pictures of the area involved. I know how to put these things back but I can't think how to explain it to you.. pics might help me show you.
Brother has an outstanding service department, and if you don't have a manual, they should have one. Should have a pic of how it goes together.
Aug 02, 2014 | Brother XL-2600
My Singer 648 is having a problem with the bobbin thread getting caught up in the bobbin case and jamming the thread inside the case breaking the thread. Is there a solution to this problem? Thanks
try changing the needle
make sure the top thread has not come off the thread take up lever
try another bobbin
make sure the bobbin is turned the right way in the bobbin case
try rethread the machine top and bobbin
clean under needle plate and in the bobbin area for lint or threads
Jan 06, 2013 | Sewing Machines
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
Bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Apr 02, 2008 | Singer 2662
Singer 7436 - INGENUITY Logo
210 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
