Question about Brother MFC-7820N Laser Printer
Scanning multiple pages
I have a brother mfc-7820n and I cannot scan multiple pages. What is the problem
  • Anonymous May 23, 2008
    SAME PROBLEM
  • clint497 Dec 15, 2008
    what about with Vista - not showing Paper Port Software in my installof Brother software
Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
Posted on Apr 08, 2008
  • 3 Answers
I have MFC 420CN and needed to scan multiple pages into a pdf. I tried the paper port software and it WORKED! :) I'm so glad I found this site!!
Posted on Jun 09, 2008
I have the same issue. Is there a solution?
Posted on Mar 31, 2008
I have the same problem! It's soo annnoying!
Posted on Mar 04, 2008
The manual that comes with my brother MFC-7840W covers all functions ACCEPT scanning! How do I scan multiple pages into ONE file so I can send a single file to someone. Thank you, Jeff Vanskike
Information on the scanning function can be found here:
http://welcome.solutions.brother.com/bsc/public/as/au/en/faq/faq_list.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
In order to scan a multi-page document into a single file, you must configure the scan to use a file type that supports multi-page documents. For illustrated instructions of how to scan multiple pages into one file instead of each scan being saved as a separate file go to here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002500/000078/faq002578_001.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
Feb 10, 2011 | Brother MFC 7840W Printer
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
How do I scan photographs on my Brother MFC-7820N. I've never used this feature. I have a Mac computer.
Hi friend,
You just install scan software in your computer. scan option will visible on your desktop then click on your scan option then ...you can scan your document.......
Dec 20, 2009 | Brother MFC-7820N Laser Printer
Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Sep 18, 2009 | Brother MFC-7820N Laser Printer
Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 21, 2009 | Brother MFC-7420 Laser Printer
Check cable 7820n
number one! have you installed the cd that came with the machine? you probaly did not install paperport which is the scanning program, may be you do not have the usb cable hooked up between the printer and the cpu?????????good luck ! brother sr tech
Feb 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Vertical lines when scanning
Clean the glass. Not the full glass where you lay a page, but the thin strip of glass that the paper moves past when you use the ADF. There is probably a small dot of ink or dirt causing the lines.
Sep 18, 2008 | Brother MFC-7820N Laser Printer
Scanning
do run the scan as a pdf
Apr 21, 2008 | Brother MFC-640CW All-In-One InkJet...
Scanning
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Brother MFC-7820N Laser Printer Logo
1,295 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
