Question about Dell 810 All-In-One InkJet Printer
Plastic strip fell off
A thin plastic strip that extends from one end of the printer to the other has fallen off and I cannot figure out how to put it back on. The cartridge is now shifted all the way to the right and I can't print. There are two small holes on either side of the strip. There is a small arrow pointing down (or up) on the one side and to the side on the other side of the stip. How do you put this strip back on the printer?
    Genius:
  • 1,142 Answers
Hi, if you open the open the printer, unit to gain access to install ink cartridge, if you see the metallic end which has got a hook on both the ends left and right side. the ink cartridge runs between the strip from left to right which should be connected above the ink cartridge meta rod.
< ------------- >metal hooks on left and right above the cartridge rod
======= __ cartridge rod
Let me know for further info.
Posted on Feb 09, 2008
My 2 year-old pulled a thin transparent plastic strip out of our dell photo 944 printer, and now it no longer works. The plastic strip appears to be the only thing he did. Where does it go, and how do I...
The plastic strip you are referring to is the mechanisim to move the cartridge carrier back and forth, you may need to take it to a certified technician to see if it can be replaced or if not damaged put back into the printer.
May 28, 2010 | Dell 944 All-In-One InkJet Printer
A plastic strip that runs behind the ink cartridges has fallen off. its a quarter inch wide and about 12 inches long. each end has a slot cut at a 45 degree angle and an eigth of an inch from the end. I...
That is the ink guide. If the plastic strip connector (the slot cut on both sides) is not damaged/broken, the other metal tab may have fallen making the plastic strip to fall. It is usually soldered on the metal frame of your printer, find the missing tab and solder it back in. You should find a trace of the tab's original location.
Apr 17, 2010 | HP PSC 750 All-In-One InkJet Printer
Plastic strip above the printer head
IT IS EASY TO PUT IT BACK AGAIN. HOOKS WILL BE THERE AT TWO ENDS.
Apr 05, 2010 | HP DeskJet 932c InkJet Printer
A plastic strip seems to have out fallen; its the
If it's the transparent strip that fell off from the assembly, it's called the encoder strip. It is, somewhat, related to sending information to the carrier's movement on the carrier shaft or the silver rod accross the printer. I'm afraid that can't easily be fixed. But, it would be better to contact Lexmark for assistance. They may be able to help you with that. Hope I can help more on this.
Mar 22, 2010 | Lexmark X5495 Printer
I have a dell V305 Printer and there is a plastic strip that has fallen off from somewhere inside. Can you advise as to what this strip is for and if it can be reinstered?
If it's a clear plastic with black lines on it, it's the encoder strip. If the holes on the end are not torn out, it installs inside from the right side to the left side, one side has a spring to connect to and the other side has a solid hook on the frame. It has to thread thru a sensor slot at the rear of the carriage assembly in order to work.
Jan 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
Plastic strip fallen off from the ink slide
You are referring to the encoder strip. They can be reinstalled. They must be threaded through a sensor on the back of the carriage.
The mount at the left side has probably been pulled out of position. If the mount is not sitting properly the strip will be loose and will cause problems. The tension mount has two flanges that must be behind the plate it is mounted on. Good luck.
Jun 29, 2009 | HP PSC 2175 All-In-One InkJet Printer
Long thin plastic piece fell out of Lexmark Z33
Google your printer, try pcappliancerepair.com. This item goes from one side of your printer to the other, passing through the cartridges holder. Look for the places it attaches. You may have to move the cartridge holder to the center to install the plastic.
May 01, 2009 | Lexmark JetPrinter Color Z33 InkJet
Lexmark z730
Try putting the plastic strip in. I think it should help. Anyways i had the same problem but mine didnt work even after replacing it. So Igot an HP all-in-one and I'm satisfied :).
Nov 09, 2008 | Lexmark X2350 All-In-One InkJet Printer
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
Plastic strip fell out
Perhaps this is the printhead assembly position "tape." On looking at this tape, are there tiny vetical lines on it? If so, then this is how the printer detects head position, as a sensor & associated circuitry counts how many lines the head has moved. It may attach at one end to a fixed hook, & with a spring like hook at the other end. It will have to be routed through the noted sensor also. This might be tricky if you don't possess some technical skills.
Apr 21, 2007 | HP PSC 1315 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
125 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
