Question about Dishwashers
Danby model # 461 14352 ,i need a wiring diagram for this unit, plus the soap dish will not open.
applianceboy
  • 77 Answers
SOURCE: dispenser doesn't open
this is actualy a water flow issue. usually caused by debris in the sump area. shut off the power, remove spray arm, top filter,ect. keep taking things out till there is nothing left to remove...if it has a screw. you will find a screen with a small blade that will be plugged. clean the screen. reasemble and happy dish washing.
Posted on Sep 28, 2007
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
freetek
  • 5568 Answers
SOURCE: Dishwasher - Kenmore 461 14352 - E2 error?
With registration, you can probably get a download of your manual (user guide) here:
http://www.managemyhome.com/mmh/
It may not contain the info you need since appliance service people hate do-it-yourselfers and, in my mind, manufacturers collude with them.
Can you believe that many TVs, radios, PC monitors etc. once came with complete circuit diagrams?
Posted on Jun 29, 2008
SOURCE: GE Nautilus Soap does not dissolve
The Water Inlet Valve is not Working. This is a small piece at the bottom of the dishwasher where the inlet hose connects to. The Valve is stuck and water will not enter the dishwasher itself. Of course this is one of the most expensive pieces of the dishwasher to replace!
Posted on Jul 26, 2008
  • 129 Answers
SOURCE: jetclean eq plus
screens , chopper ,and spinner arm stopped up take apart and clean
Posted on Feb 05, 2010
Danby counter top dishwasher leaves residue on dishes
Make sure It's not a soap issue by running a load or three without any detergent.
Jan 11, 2015 | Danby Dishwashers
Soap dispenser door doesn't open during washing
make sure top rack is not jammed with dishes and is pushed in all the way.
Feb 10, 2014 | Danby DDW1899BLS Builtin Dishwasher
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
Dishwasher cup won't open
Make sure no dishes have block it from opening. If this is a dial model, then with the door open so you can see the soap cup, turn the dial and see if it opens up. If not replace soap cup.
Oct 01, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Water pools in bottom of dishwasher and dishes come out dirty
Pump is stopped up, or bad, can you here the pump run, if so drain and make sure there is nothing in the intake of the pump.
Dec 27, 2008 | Danby 22 in. DDW396 Free-standing...
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Dishwasher
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Apr 23, 2008 | Dishwashers
Dishes are not clean due to insufficient water. Arms are clean, strainer is clean, water supply is OK,some soap is still in opened dispenser
Disassembled solenoid, found plugged inline strainer (caused by water shut-down in building to replace recirc. pump) Pulled and flushed filter basket, problem solved. Solenoid must be removed to access filter which is in sol. body. I hope this can help anyone who does'nt have a tech manual or flow diagram.
Mar 29, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwasher wont clean
You need to rinse the dishes first and then do not cover the dishwasher soap dispenser
Jan 02, 2008 | Danby 22 in. DDW396 Free-standing...
Danby countertop dishwasher
i would think the drain hose from the unit is leaking from the description you give.let me know
Dec 24, 2007 | Danby 22 in. DDW396 Free-standing...
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
