Question about Durabrand DB1200 CD Player
Hooking up i have a 92 gmc jimmy and the wires are different and the antenna wire plugs in in a different spot so what do i do
  • 41 Answers
Get it installed by someone who knows what they're doing
Posted on May 09, 2008
My pcm came unplugged without the battery unhooked on a 96 gmc jimmy now wont start
I don't know what you mean by, "I plugged it back up". Did you mean that the harness unplugged or that a wire came out of the plug? Inspect the fuse-box. Look for a blown fuse. You can try disconnecting the battery for 30 seconds. If the stock stereo has the anti-theft feature, remember to disable it first. If a wire did in fact break away then you will need to do more than just push the wire back into place. Please write back with any questions or status, good luck.
Mar 27, 2014 | GMC Jimmy Cars & Trucks
1996 Gmc Jimmy will not start new wires plugs dist. rotor act like it will start but does't
you are out of timing or you put your distributor 180 off or you may have hooked the plug wires up wrong you may have 2 in the wrong place
Apr 16, 2013 | 1996 GMC Jimmy
I need a diagram for the spark plug wires for a 94 GMC Jimmy V6 w/Vortek
1994 GMC S15/T15 Jimmy 4WD 4.3 liter V-6 VIN "W"
Hope helps (remember to rate this answer).
Mar 21, 2011 | 1994 GMC Jimmy
Radio in 88 lincoln town car doesn't pick up stations but cassette works just fine. Everything is hooked up, harness, speakers wire, ground wire, and antenna. I also checked to make sure that the antenna...
Probably bad antenna wire at the antenna itself. Try plugging a piece of bare wire into the antenna hole (the 1/8" hole in the center) on radio, you should get something, hissing or some sound.
Feb 08, 2011 | 1988 Lincoln Town Car
Before tune ran fine, after tune up started missing
WELL THE FIREING ORDER IS 1-5-3-6-2-4 #1 IS CLOSES TO CRANK SHAFT PULLY HOPE THIS HELPS
Aug 12, 2009 | 2000 GMC Jimmy
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 08, 2009 | 1996 GMC Jimmy
Wont start in rain
Jimmy fx:
Since it is moisture related I would suspect the ignition system. My F150 pickup started running poorly and on a hunch I replace the plug wires, the distributor cap and plugs. It made all the difference in the world
Good luck Loringh
Nov 15, 2008 | 2001 GMC Jimmy
Car stereo wiring
MOST GM Vehicles P o w e r Memory (+12v Constant) - Orange or Red Ignition (+12v Switched) -  Yellow Ground (-) - Black Illumination - Gray Dimmer - Brown Power Antenna  - Pink or blue
S p e a k e r s Right Front (+) Light Green Right Front (-) Dark Green Left Front (+) Tan Left Front (-) Gray Right Rear (+) Dark Blue Right Rear (-) Light Blue Left Rear (+) Brown Left Rear (-) Yellow
Sep 09, 2008 | 1994 GMC Jimmy
Installing radio plug for cd player conversion
i got it installed after all thanks for the email back.
Jul 19, 2008 | 1992 GMC Jimmy
Durabrand DB1200 CD Player Logo
50 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
