Question about Samsung LN-S2651D 26 in. LCD Television
Shop mode - home mode
Hi how to change shop mode to home mode ?
  • Anonymous Jul 16, 2008
    i have the same problem
  • Anonymous Jul 19, 2008
    to turn off shop mode samsung la46s81b
  • 372 Answers
Hi.
Try This it might work.
  1. Enter Service Mode - (Press Menu -> Mute -> Power On)
  2. Navigate to SHOP MODE, set this to OFF then select OK
  3. Turn the set off to exit the menu
  4. Turn the set back on and reset the picture settings
  5. Turn the set off and back on again to verify the settings have been stored.
http://dysonmanuals.llc.nu/
Chris.
Posted on Feb 08, 2008
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
Demo mode keeps on popping up on sony bravia. how do i permanently remove it
hi,
you can exit the DEMO MODE by the following setup.
Power ON the television
1. select "TV" mode (not AV, demo mode can't switch off when ur in AV)
2. Press the "home" button on the remote.
3. select "settings".
4. select "set up" .
5. Scroll down to "factory setting" and restore them.
6. when it asks home or shop display select "home".
ok
Jan 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How to get rid of demo mode
hi
do the following
1.Press the home button on the remote to go to the cross bar
2.Choose settings
3.Look For set up
4.Scroll down to factory setting and restore them.
5.After that it will go to set up mode when it asks home or shop/display select "home"
ok
Dec 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Sep 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
I own a Sony Bravia KDL-32V2000 and whenever I 'tun off' and 'turn back on' I have to re-dedicate the TV i.e go into menus external ouutputs, then scroll down to AV4. Surely there must be a way arouns...
Unfortunately I am still to resolve this problem but due to having recently been made redundant I am not in a 'financial position' to pay for a 'remedy!
Sorry
Mike
Sep 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
My Samsung LNT3253H LCD TV has suddenly started changing its own settings (e.g. picture mode keeps switching to ''dynamic'' and the ''light effect'' keeps setting itself to ''always on''). Any thoughts on...
Its in "Shop Mode".
Change your source to TV (analogue), now press menu>find "Plug and Play" and select it and runs through the setup and selct "Home" prompted and not "Shop".
That should sort its out, when its in shop mode its doesn't matter how many times you make changes, when you power it off it will go back to the original shop settings, this feature was built in to allow shops the have all show TV's to run at optimal settings and if a customer played about with the settings it would matter as they are reset again when the TV is switched off and the store staff don't have to go around resetting all the TV's at the end of the day.
Thanks
Sep 05, 2009 | Televison & Video
Don't store tv setting LCD40F86BD
im having the same problem, i have had this television for 16 months now. its not just happening when i turn it off but also when im changing the source
Jun 12, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Can't use "plug&play" from TV menu
I can switch between shop mode & normal by holding down the menu key on the side of the screen, just press it till it changes.
Jan 07, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung lcd tv le32r8 (Picture - Movie setting)
The TV is probably in Shop mode, when your TV is initially turned on you can choose between Shop mode or Home Mode.
In Shop mode the TV automaticly returns to the standard setting after a while, they do this so customers can "play" with it.
Press down de Volume button and then hold down the Menu button for five seconds on the side panel of the tv.
Oct 25, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung LN-S2651D 26 in. LCD Television Logo
1,151 people viewed this question
Jerry Greenberg
Jerry Greenberg
