Question about Acer Aspire 3000 Notebook
Mouse touch pad
I have two problems.
1, My friend's toshiba satellite 3000's touch pad is not responding at all but the usb one is working fyn. How to I activate this?
2. My satelite a200's touch pad worked well when I bought it but now it works but does not do the double-clicking and other things
I couldn't find an answer online, I have a Toshiba satellite with Vista and the clicking wasn't working on the pad. I found the answer....
open control panel...
hardware and sound....
mouse....
the tab Device Settings
click Settings
click Tapping on the left
click the check box enable tapping
and for everyone with problems with nothing working on the pad at all hold down the FN key next to the control key and press F9
Posted on Dec 04, 2008
My touchpad and keyboard stoped responding in normals windows mode but did work in safe mode. When I looked into this problem- and after much time and effort- I found that the problem was caused by the battery. It had simply worn out and even with the mains power plugged into the laptop the keyboard and touchpad would not work. I replaced the battery and the problem was solved. That could possibly be your problem??
Posted on Feb 07, 2008
    Problem Solver:
  • 17 Answers
All u got to do is download the driver for the touch pad and it should work hope this helps
Posted on Feb 05, 2008
Why has my mouse stopped working, also the touch pad on computer has stopped?????
Janice, This is info from Tomsguide.com
1- Turn off computer, disconnect the power cord, remove the battery.
2- Press the Power On button for 10 seconds
3- Replace battery and/or connect power cord.
4- Turn On computer + immediately press F2 key repeatedly
5- Press F9 then press Enter
6- Press F10 then press Enter
May have virus or corrupt driver, run your anti virus and try reloading divers for mouse and touch pad, you may have to use system restore to an earlier date when thins were working OK.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ccm.net/forum/affich-689275-toshiba-satellite-mouse-pad-stopped-working
Toshiba Satellite keyboard and touchpad don work
Toshiba Satellite Cursor is not responding
Jul 31, 2016 | Toshiba Computers & Internet
The mouse on my laptop doesn't work, but the external mouse plugged into the usb does. Any suggestions?
Touch Pad setup with the usb mouse installed for easy navagtion
check the device manager for mouse mouse and other devices
look for nthe touch pad label
look see if it is running ok and enabled.
Make sure it is.
Go to control panel open the mouse icon
touch pad mouse properties
Here is where the controles for external and internal mouse settings will be found.
The rest is up to you
Jun 26, 2010 | Toshiba Satellite A100-S8111TD Notebook
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
Touch pad not working properly
Plug in a usb mouse and go to control panel>system>hardware>device Manager (if using XP) or control panel>system>device manager (if using vista) and right click on pointing devices, unistall the touch pad and reboot - remove the usb mouse and the touchpad will be installed again as new hardware. I hope this helps
Nov 28, 2008 | Toshiba Satellite A135-S2276 Notebook
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
I need to disable touch pad and use a usb mouse
Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
Toshiba satellite 1805 windows xp touchpad does not respond to one or two clicks although it does move the arrow around
Go into your controll pannel then click on mouse. On the mouse properties click on Touch Pad, then you can change the settings for sensitivity of the touch for double clicking with the touch pad.
Apr 28, 2008 | Computers & Internet
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
499 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
