Question about Fuji FinePix F410 Digital Camera
Focus Error When I turn on the camera "Zoom Error" comes up on screen. Will take pix, but very out of focus. Tried turning on / off; removing battery etc, but problem will not go away. Lens cover does not close when this problem occurs. Is there a "Master Reset" button?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.
Problem is fixed and focus now working ok.
Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error
Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start working. I need to make small adjustment . Reason when camera is started picture is not clear and before using camera i need to do full zoom in and back zoom out. After this picture is crystal clear and all working ok.
Dec 17, 2012 | Fuji FinePix S304 Digital Camera
We have a message coming up saying "zoom error"
If the camera was operating properly before the zoom error then the most common problem to a stuck lens is dirt getting stuck between the two lens barrels. There are a few fixes for this none are guaranteed to solve the problem and should not be attempted if the camera is under any type of warranty. They include removing the batteries for a few minutes, reinstalling the batteries with fresh once with full power, turn the camera on while holding the the zoom button. Another method is to see if you can provide extra power to the focus motor by having the LCD screen turned off. There my be a button that allows you to switch from the viewfinder to the LCD screen switch to the viewfinder and try several times to focus (just point the camera at different distant objects) and attempt to focus the camera. I hope this gives you the results you need because the other suggestions may further damage the camera and are only a (last resort) thing. One is with the camera turned on tap the body on a counter or table edge while trying to zoom the lens obviously in the opposite direction to where it's stuck. The last is to gently push the lens in with the palm of you hand while zooming in. All these are just suggestions and carry no guarantee of working and may further damage the camera. The biggest cause of this problem is dust from a camera bag or some other environmental condition like sand from a beach.
Jan 24, 2011 | Fuji FinePix S1000FD Digital Camera
I receive the E:61:00 error on screen, and the screen will not focus. I shook the camera around (per forums) and the screen focused for a minute, but would not zoom in out out. When I tried to zoom either...
The E:61:00 error code displayed on the Camera screen indicates that a Camera malfunction that you cannot reverse has occurred. This seems to be an internal malfunction of the Camera. You may try power resetting the Camera. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, service may be required as this is an internal malfunction
Thanks for using FixYa.
Jan 18, 2011 | Cameras
Does the fuji fine pix camera have a focus button? where is it?I want to be able to zoom in on a subject without losing focus.
No, your camera does not have a manual focus button.
Even if it did, you wouldn't be able to keep focus while zooming.
Only very expensive lenses maintain focus regardless of focal lenght.
The correct procedure is to zoom and then focus.
Nov 12, 2009 | Fuji FinePix S700 Digital Camera
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Jul 22, 2009 | Fuji FinePix A400 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
Camera won't focus when using optical zoom
I had same problem. Found that doing a complete reset fixed it. Go into setup and at end there is a factory reset. If not working after that would suspect your ccd sensor is on way out. They should last 5-7 yrs. Be cheaper to get another cam with way prices have come down
Jan 08, 2009 | Fuji FinePix S5000 Digital Camera
Zoom error
Turn Camera off remove batteries for a few moments. Re insert batteries. Turn on will reset itself. Ensure you use correct focus settings as per instructions. If you dont use correct settings this problem will reoccur.
Oct 27, 2008 | Fuji FinePix S1000FD Digital Camera
Focus error
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
May 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji FinePix F410 Digital Camera Logo
55 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
