Question about Acer AC713 17" CRT Monitor
Monitor problem of contrast
I am getting contrast will be full of 100 in the monitor screen
  • 749 Answers
Hi
You can adjust the monitor by having a knowledge in electronics and some experience to do this.... Try adjusting it through the plyback area... It will work 100%.
Be careful, a simple mistake can destroy everything of kill yourself with electricity...
I hope you got my point.... We want to help, safety first remember.
Hoping a Fixya result on this one....
Posted on Feb 05, 2008
5 Suggested Answers
  • 32 Answers
SOURCE: On start, monitor contrast option automatically gets activated
if nothing works and you cannot access your monitor settings via the menu button on the monitor then you have no way of correcting it. as far as i am aware the only thing you can change with the monitor from within your operating system are its resolution, refresh rate. so i think you need a knew monitor.
Posted on Apr 23, 2009
  • 17 Answers
SOURCE: monitor problem
It seems to be pulling up the contrast settings on the monitor. Try tapping on the buttons on the monitor. If the buttons are stuck you need to get it repaired. Find a local repair shop.
Posted on Aug 08, 2009
  • 10 Answers
SOURCE: The contrast of my PC monitor increases
problem with front panel control switches. especially brightness increase control button. need to replace the switches.
Posted on Sep 20, 2010
SOURCE: The contrast of my PC monitor increases automatically to 100%.If
Check this solution :http://www.fixya.com/support/t2918231-acer_ac713_monitors_brightness_value
Posted on Oct 20, 2010
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Why would I keep getting a red rectangle box in the middle of my monitor screen that says " CONTRAST 100
It's there to notify you that a setting on the monitor is not wisely selected - lower the contrast to less than 80. Ideally you should reset the monitor to default values - use this option from the menu.
Sep 19, 2010 | Dell Computers & Internet
Contrast 100 box
That would be the monitor and not the PC. try going to menu on the monitor and doing a factory reset.....if that doesn't work unplug for 3mins and try agin....if neither work then your monitor is faulty. Hope this works out for ya
Nov 02, 2009 | Dell Dimension 2400 PC Desktop
Monitor problem
Aug 08, 2009 | Computers & Internet
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
Contrast 10My problem is that the contrast is appearing in the screen of my flat screen and automatic decrees the contrast and it?s blocking the center part of the screen window keeps appearing on scr
There is no feasible way to fix this. The problem is a short in the circuitry of your flat screen. If the monitor is off warranty, it's cheaper to replace the monitor than to have it repaired.
Jun 02, 2009 | Dell Dimension 2400 PC Desktop
Apr 23, 2009 | IBM E54 15" CRT Monitor
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
Contrast automatically increases to 100%
yes! The same problem in my monitor. The contrast of my PC monitor increases automatically to 100%.If I try to reduce it,it increases again.
Oct 19, 2008 | IBM E54 15" CRT Monitor
Acer AC713 17" CRT Monitor Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
