Question about Xerox DocuColor 12 Printer
Print margins too large on Xerox DocuColor 12 - How do I reset?
We often print to SRA3 from tray 5. This should mean we can get 2 x A4 documents side by side - even when allowing for 3mm bleed & trim marks. However, the outer edges of the artwork never quite fit on the page - they are chopped off. The print margins appear to be set at around 20mm. I don't believe this is to do with the way the file is set up to print as I've printed 2 up on SRA3 many times in the past to other Xerox DocuColor 12's. Can you help?
Kind regards lisa@hortonprint.com
    President:
  • 2,072 Answers
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Posted on Feb 13, 2008
What does it mean when a dc12 Xerox print with two faded lines when printing from tray 5 is it a problem with the drum or the belts?
answer # 0034 Drum
You can check the developer 'brush' by taking out the drum and looking at it. check the manual PDF download here.
Note: link take a few minuts before download please wait.
techbelkin
Dec 20, 2010 | Xerox DocuColor 12 Printer
Page margine
The doc 12 does not print tot the edge of the page. What size of sheet are you printing on and what is the size of the margin?
Oct 27, 2010 | Xerox DocuColor 12 Printer
Xerox DC12 Fiery EX12 Print missaligment
caopy can be set by NVm Code 720-001 for side A
720-002 for Side B
please note down initial values before changing it
Apr 21, 2009 | Xerox DocuColor 12 Color Copier
SRA3 printout is not same size but slightly smaller
Try this!
Phaser 7300 Printer: Turn metric defaults on using the printer's front panel
The Printer's Configuration Page will show that Tray (1-5) is loaded with Tabloid Extra instead of SRA3. To have the image scaled to SRA3 instead of Tabloid Extra, turn On Metric Defaults at the Printer's Front Panel.
You can switch Metric Defaults On or Off at the Printer's Front Panel as follows:
  1. With Menus highlighted, press the OK button.
  2. Select the Printer Setup Menu by pressing the Down or Up Arrow button.
  3. Press the OK button.
  4. Select the Reset Printer Setup Menu by pressing the Down or Up Arrow button.
  5. Press the OK button.
  6. Select Metric Defaults by pressing the Down or Up Arrow button.
  7. Select On or Off by pressing the OK button.
Dec 29, 2008 | Xerox Phaser 7300DN Laser Printer
Margins
The effective print area of the DC 12 is 297mm x 438 mm which is why you have the border.
Oct 14, 2008 | Xerox DocuColor 12 Printer
Xerox phaser 7700 having problems printing transparencies and accumulator belt problems
Hi xander4265:
I
Streaks in direction of paper travel
There are dark lines running along
the page in the direction of paper
travel from the leading edge to the
trailing edge (B-size print shown).
The printer displays no error code.
Note A-size prints are processed
through the printer with the short
edge of the print parallel to the
direction of the paper path --
making horizontal print artifacts
parallel to the shot edge of the
print.
B-size prints are processed
through the printer with the long
paper path -- making horizontal
artifacts parallel to the long axis
of the print.
1. Check the end of life for each of
the consumables by printing the
supplies usage page. From the front panel’s Printable Pages Menu, select
Print Supplies Page.
2. Run the solid fill test pages; From the front panel’s Printable Pages Menu,
select Service Pages, then select Print Solid Fill Pages. If the missing bands
only occur in a single primary color, replace the print cartridge of the affected
color.
3. Swap print cartridges and run another test print.
Note Under some circumstances, streaking may occur in the margin of
SRA3-size paper. This is due to the edges of the paper extending
beyond the end of the imaging components. print-quality in the
margins of SRA3 paper is not guaranteed.
4. Inspect the Accumulator Belt cleaner; replace the cleaner, if necessary.
5. Run the Remove Print Smears routine. From the front panel’s Support Menu,
select Improve Print-Quality?, then select Remove Print Smears.
6. Replace the Developer Housing Assembly (RRP 27, on page 7-171).
7. Remove the print cartridge and (with a flashlight) check for debris along the
edge of the developer housing.
3041-42
Leading Edge
hope that this will help you.
Sep 18, 2008 | Xerox Phaser 7700 Laser Printer
Tray 5 is broken
Try modification kit avaliable
Mar 28, 2008 | Xerox DocuColor 12 Printer
Top Margin print cut
If you are using the bypass (tray 5), you need to move the limit of your tray from the normal position to 12" position.
Hope this help.
Nov 29, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
793 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
