Question about Pentax K100D Digital Camera
Bad USB conection?
Hey there,
My camera has been working fine for me, but I just tried uploading photos onto the computer and the computer doesn´t recognize that anything is plugged in.  The camera is on, the cords are all connected...could it be that my USB cable has gone bad?
I have a K100D and the USB fitting failed in the first 5 months - not a major as I usually use the card reader to get photos transfered.
Camera is now at Pentax as the flash failed as well ( my 3rd pentax and the only one I have had any problem with) Pentax are insisting on fixing the problem and we will have to negotiate who pays.
Anyone else had issues with their USB on Pentax SLRs
  • Doris 007 Mar 09, 2008
    Thanks racer, the actual USB connection point failed and was loose - a hardware issue. I was curious to know if anyone else had the same issue. It has been over 6 weeks since I had my camera and I miss it heaps....
    Halotheracer.... my first log was in reply to someone elses comment - I don't know how to edit it so that the issues are separate. Thanks for the followup
    Megan
    Problem Solver:
  • 18 Answers
Make sure you K100D's Transfer Mode is set to "PC"!!!
In the K100D's "Menu" under "Set-up" there is a setting for "Transfer Mode".
This setting tells the K100D how to configure it's USB connector.
There are three settings.
PC
Pictbridge
PC F
PC is what you use to get the K100D to communicate with your PC.
Pictbridge is what you use when you hook up the K100D to an inkjet printer (with Pictbridge capability) to print pictures directly from the camera.
PC F - I don't know. Never used it.
Take care & Happy Imaging!
Glen
Posted on Jul 26, 2008
  • 68 Answers
I assume that you are using Win.XP,
- did you check; System Properties>Hardware>Device Manager
Is there anything like yellow exclamation etc, especially on the USB section?
- Is it BIOS USB function enabled? Maybe disabled by accidentally.
- You said nothing working through USB, all ports are same?
If this ocurred all of a sudden, than I think you have a software problem.
I have a K100d, its been seven months now and ~6500 photo. My USB cables&fittings are fine, I always using USB port to transfer photos, no problem at all.
I hope your problem will be solved in a short time.
Sincerely
-halotheracer-
Posted on Mar 09, 2008
  • halotheracer
    halotheracer Mar 09, 2008
    On your first post, you said "the computer doesn´t recognize that anything is plugged in". As I understand that all your USB ports are down (I have 6 USB ports on my computer, I guess you have at least 4), since this pointed rather a software problem but on your second post you said your USB connection point failed/loose.
    At the camera side or the computer side?
    If the camera side is loose, maybe you can try another USB connection cable to solve this.
    Reminder: K100D uses one side "micro" one side "A-Type plug" USB cable.
    Good luck.
Bad USB conection?
If your camera's driver is not installed, it will not work.
Make sure you go to the manufactures site, and download the correct driver there.
However, if your driver IS installed, then yes, your USB cord might have gotten bad.
Thank you.
Nov 26, 2007 | Pentax *ist DL Digital Camera
Every time I try and upload pictures onto my computer using my Nikon s4000, the pictures are extremely distorted, but look completely fine on the camera itself. I use the chord that came with the camera to...
this is a very odd problem, I have the same camera and it works fine, your best bet is to buy a usb SD memory card dongle. they are about 14 dollars, this will solve your problem with the photos, but I don't know why your camera won't work properly with the cable., have you tried it with the cable on your friends computer?
Mar 11, 2011 | Nikon Coolpix S4000 Digital Camera
I have a new computer,my finepixviewer was installed on my old one worked fine. I have down loaded my finepix Cd onto new computer. It has insalled ok but will not conect to server to down load extra...
Did you try contacting Fujifilm online support? This may be because you have not registered from the new computer to whatever program you are trying to connect. If your problem is about running the software already installed, why not consider using third-part software to download, and edit your photos. picasa for example.
Please rate fixya answers
Mar 10, 2011 | Fuji FinePix A500 Digital Camera
Bad USB conection?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 11, 2009 | Pentax K100D Digital Camera
Uploading pictures
I use a standalone cardreader, that i plug via USB to my computer. This solution works very fine.
Feb 29, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Sony cybershot
Hi cozzyalice,
I may have a solution on uploading your photos.try to re-install your digital camera softwere drivers. that will let your computer identify the usb.
Jan 16, 2008 | Sony Cybershot S650 Digital Camera
Is the problem occuring in the USB, Memory Card or the Camera?
hello, i have the same camera, the LCD is not bright i can barely see the LCD, any of you have any idea how to fix it wihtout having to send it back to warranty? i checked al the settings and they are right the LCD should be working well.
i will really appreciate your help.
Dec 26, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Bad USB conection?
it's not likely the cable went bad.  Do you have more than one USB port you can try? do you have other USB devices to test the port? did you reboot?
Oct 12, 2007 | Pentax *ist DL Digital Camera
Uploading images to laptop
By default, Windows uses a 32bit FAT when formatting which is NOT compatible with most cameras. I'd suggest sticking to using the camera menus for formatting a card, unless the camera can't format one (then, if you must use a PC for formatting, make SURE you select FAT as the File System Type). I'd also recommending formatting again with the camera menus before using a card if you ever do need to format one with a PC. As for your problem with the laptop seeing the card, it could be any number of things. It's more likely related to the USB drivers. Many users report intermittent problems with USB connectivity after upgrading to SP2. A frequent solution that sometimes works is removing all devices drivers related to USB (My Computer, Properties, Hardware, Device Manager). Then, rebooting and letting Windows find and reinstall the drivers again. Sometimes, updating these drivers can work, too. You may also be seeing a conflict between other USB devices and drivers. For example, sometimes HP Printer Monitor software conflicts with USB connectivity to other devices. You may also want to try a different USB Port. If all else fails, consider a Card Reader (they're very inexpensive now -- you can probably pick up a USB 2.0 card reader for around $20.00 locally). With a laptop, you may also want to consider a PCMCIA based reader.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Pentax K100D Digital Camera Logo
221 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
