Question about Marantz SR-5200 Receiver
I can not get surround mode on my Marantz 5200 receiver
I own a Marantz SR5200 receiver and have done so for about 6 years. I have attached to it a Cambridge Audio 80 series DVD player. I have never had any problems with it and it has worked perfectly fine.
I have recently moved house and when I have reconnected the DVD player to the receiver, the sound works but I can no longer get surround sound and it only plays in stereo. The surround mode is set to auto and I have tried different settings to ensure its not that. I have tried different dvd's to make sure its not the dvd. I have checked the speakers and the testing works (ie. all 5 speakers work) but still no surround sound. I have looked at all the settings including on my DVD player, but still no surround sound.
The only difference between the previous setting and the new one is that I have connected the scart to a new flat screen TV, and i am using a new 10 m scart cord as the DVD player and receiver are farther away from the TV location. However, I do not see how that would impact the surround sound as the DVD player is connected by the same digital cable to the receiver as before and in same places.
Your help would be appreciated.
  • elsarivka Feb 05, 2008
    I have the pioneer vsx 100 and have same problem with mine moved house set up gear again on the lcd display it says there is a input signal ie dolby digital but there is no output signal i just get stereo sound.
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Apr 21, 2009 | Marantz SR-5200 Receiver
No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Feb 21, 2009 | Marantz SR-5200 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
SR-5200 owners manual
http://www.retrevo.com/s/Marantz-SR5200-Receivers-review-manual/id/511dj791/t/1-2/
Jun 26, 2008 | Marantz SR-5200 Receiver
Loud distortion on Front Channels
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from mcminone.com or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Jan 12, 2008 | Marantz SR-5200 Receiver
Statics and hissing...
I also have the same fault, The static noise is coming out
of ic720 [ cs4391 or cs4392 ]on digi pcb which is D-A converter
this ic maybe faulty, i have ordered a replacement ic and will
post here if solves problem
Dec 10, 2007 | Marantz SR-5200 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
819 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
