Question about OKI C5300dn Led Printer
Paper Jam wrong error message "Open Front Cover"
Although there is no paper jammed I get the error message (380) that is is. Cannot print. Any solution?
I have the same problem.... Any solution?
Posted on Jan 03, 2011
380 paper jam
Pull out the toner&drums and see if its under there
Oct 08, 2009 | OKI C3200n Led Printer
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
New out of the box 13:20 error paper jam there has never been any paper in machine we're just setting up. open and close front, then theres a fuser jam lift and close top, front door again.We have paper in...
PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
Jun 24, 2009 | HP LaserJet 3600n Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI C5300dn Led Printer Logo
495 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
