Question about Fuji FinePix S5000 Digital Camera
Fujitsu/siemens scenicview e-19-1 model 900p
Hi all, I have this monitor just over a year, when it decided to go faulty. when u power up the screen comes on then shuts off. you can turn it off and back on and the screen will come back for about 5 seconds and goes blank again..the led light stays green as if its working away ok. Anybody come across this before? any ideas where to look ? thanks Hi! I´m from Portugal, and I have the same problem with my monitor. When I bought this monitor, 7 months later, I had this problem, but I had the guarantee and the problem was solved. Now, 3 years later, i´ve the same thing. I just read here, that the problem should be whith clip JP13. Yesterday, when I opened the monitor I localeted that clip, but i dont know what to do now. I took some photos and here they are: http://img85.imageshack.us/my.php?image=img014aa0.jpg http://img85.imageshack.us/my.php?image=img016st8.jpg http://img85.imageshack.us/my.php?image=img017ek5.jpg I hope that you can help me. Thanks a lot, Andr?
  • Anonymous Apr 03, 2008
    Have the same problem, anybody fixed that???
  • Anonymous Dec 27, 2008
    I have the same problems witch this model 900p. But if I want turn on I should some times turn on and turn off monitor anl later I can turn on.
    Tom from Poland.
Yes that is the right board in the PSU.
I have fixed one of these myself by cutting JP13 - it is on the top (cream side of the board)
Looking at this picture (and from my memory)
It is one of the four wires (which are near the screw hole in the lower right area of the picture - shown running top to bottom.
From memory this was the left hand one of the four but it was clearly marked on the board
I simply cut the wire to break that circuit and bent the wires so that they wouldn't short on anything, then re-assembled - and it worked a treat!
Posted on Oct 15, 2008
Okkljkljkl
Posted on Mar 11, 2008
Okkljkljkl
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Brock
Sep 16, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Can u help me? - Fujitsu-Siemens 900P LCD monitor burned out
Hi..there,
It's seems you got busted capacitors. Replaced all 5 capacitors in right handside with( 5*c8) in the 3-jpg photo power/inverter board.
Feb 03, 2009 | Computers & Internet
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, In the Power Supply Section, in fact ALL Electro's are suspect and often I often simply just "Shotgun it" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps. The "Faulty" ones are usually misformed, domed, or split.. but sometimes there is NO external evidence.
Jun 09, 2007 | Fujitsu Siemens Business Line E18-1 18.1"...
Fuji FinePix S5000 Digital Camera Logo
723 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
