Question about Sony Ericsson K750i Cellular Phone
K750i joy stick stuck
My joy stick is stuck and won't budge, somtimes it does with a bit of force but most times it selects rather than navigates.
  • mail4marsh Feb 08, 2008
    i havnt come round to taking it to the repairs but a friend with a similar problem comfirmed the way to have worked, thank you very much, will recomend you.
  • mpisula Apr 03, 2008
    Has anyone found what the issue is with this. This joystick drives me crazy.
  • 36 Answers
this problem is happens in sony ericssons most of modeles
your problem is similer to those. if you can able to open the phones frontcover just open the two scroows from back side then safly remove the front cover by pulling their interlock . then remove the keypad fouil and joystick cap, and just 2-3 drops of
i.p.a. or alcohal drops in to the in side the joystick and continew
press it for 8-10 time. then close the same . if not works then you need to replase the joystick switch with new one by trained
mobile engineer.
vyas
Posted on Apr 04, 2008
There Is A Way To Remove The Cover So You Could Remove The Front,
Or If You Get Some Sort Of Rounded Clamp Or Something That Will Not Crack. then pull it outwards. or take it into a phone shop and they could easily remove the cover.
Posted on Feb 05, 2008
Thermostat staying to cold not goin up to half way then dropin back down 'somtimes just stays at bottom
  • Sounds like your thermostat is stuck OPEN. Most the time a thermostat sticks closed and makes the vehicle overheat from lack of circulation. A thermostat can stick open also and you won't get any significant heat in the vehicle from over circulation. Might want to replace the thermostat.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Ford Focus Cars & Trucks
Can i put a k750i housing/fascia onto a w810i?
yes you can change the back only because the k750 has a joy stick which is different from the w810
Jan 11, 2010 | Sony Ericsson Walkman W810i Cellular Phone
PS3 SCROLLS DOWN AND WONT SCROLL UP!!
This kind of thing happened quite a bit on older gaming systems if the joy stick was tilted while booting. If this still happens when you leave the controller sitting on a flat surface while booting, the joy stick sensor may be a bit stuck - usually you can solve this by clicking down on the left stick and or moving it somewhat violently for a few seconds. If that doesn't do it try a silicon based lubricant, wet a section of cloth with it and then wipe it on the exposed based of the joy stick - move it around a bit to get it inside and try it then.
May 30, 2009 | Sony Playstation 3 (PS3) Console
My need k750i phone lock code
my display often turns off automatically and i have joy stick problem more
Jan 10, 2009 | Sony Ericsson K750i Cellular Phone
Joy stick
my mobile name is sony ericssion k750i it's do not work joy stick properly since 1 month pl solve this
Jul 14, 2008 | Sony Ericsson K750i Cellular Phone
Dodge caravan ignition sticks sometimes key won't turn at all.
sounds like you need a new ignition cylinder. normally when this happens you can tap on the bottom of the column where the cylinder goes into it with a hammer while jiggling the key should un stick it temporarily
Jun 02, 2008 | 2003 Dodge Caravan
Restart problem of k750i
hai this is not a problem of memory card,and its only joy stick problem,so plz clean that or replce that
then automatically solve your problem.
Feb 10, 2008 | Sony Ericsson K750i Cellular Phone
Problem with buttons &navigations.
Double check that none of the buttons are stuck down. Try removing and replacing the battery.
Sep 26, 2007 | Sony Ericsson K750i Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
149 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
