Question about Gateway FPD2485W Television
HDMI input - not scaled and not centered correctly
When I attached Samsung DVD-R155 (with built in tv tuner) to my Gateway, the picture does not take 100% of the screen size, leaving a couple of milimters (up to a centimeter) either on the right side of the screen (picture not centered) or on both sides. This is irrelevant of the video scaling mode selected on Gateway, and irrelevant of upscaling mode on Samsung.
lukster
  • 217 Answers
SOURCE: 2 inch black vertical line near center of screen
It depends where the line is centered most, to the right or left of the center, there are buffer boards that control the vertical video, on the bottom part of the unit if you take the back off and look at the bottom part of the set you will see these address boards, they are usually about 2 inches wide and could be labeled J or K, if the unit is High Definition then you could have these buffer boards on the top part of the unit also
Posted on Feb 17, 2007
SOURCE: Gateway TV
I have had the same problem on my gateway plasma for a year now. My 2nd TV just started to show similar defects on the screen. I can never get a straight answer as to what causes this problem yet it is a very common defect on these tv models (gateway) most accurate answer I got from gateway was that it is better to buy a new one.
Posted on Jan 23, 2008
leecom72
  • 4806 Answers
SOURCE: Compatible motherboard for Gateway GT4016 Case
Any Micro ATX motherboard will do for that case type
Good luck
Posted on Jan 26, 2009
  • 28 Answers
SOURCE: TV tuner and Cablevision box incompatible
Thanks for your update ertbs500, you may be able to just run an HDMI from that cable box to the PC but I have never done that and I have never done a TV tuner card either.
Low signal strength makes no sense at all seeing as how the coaxiel is plugged DIRECTLY in to the tuner card. Low signal would be from wireless. Maybe it is talking about wireless and somehow the coaxle is not transmitting signal for some reason, or the PC is not seeing it. Sorry I can not be of more help! I would look online for forums or guide on how to set up Media Center for your tuner card.
Posted on Mar 19, 2009
If you have a black stripe probelm on your Gateway TV, check out pleasefixitdave@yahoo.com. I asked him for help last year (September '08) and his solution worked perfectly. Still no more stripes (I had 4 of them) and here it is June 23, 2009!!
Posted on Jun 24, 2009
We have a Samsung Smart TV. We cannot get the signal and have installed a Digital Satellite Receiver. We have a Magnavox VCR and a sony DVD Player. We owuld like to attache the same to our TV and watch...
Depending on your Satellite receiver's output type (i.e. HDMI or Component - Red, Green, Blue) you should connect to your tv's appropriate external inputs. Example: if you choose to connect the receiver via HDMI, then you use the SOURCE button on your tv and select the correct HDMI input you have connected your device to. If connected by Component (Red, Green, Blue) then use the SOURCE button to select the correct Component input, and so on.
Note: HDMI is the best connection type - you won't be able to access your receiver from the tv's built in tuner.
As above explanation, your VCR and DVD devices should be connected to your tv in the same manner - unless it is a combo unit (VCR & DVD in one), in which case this device can be tuned into your chosen tv channel (via the tv's tuner).
Note: if you have one of the latest SMART tv's, it should already have a built-in "Hi Definition" tuner which will allow you to watch free digital tv broadcast (DVB).
Hope this helps...
"Please rate this solution"
Aug 28, 2011 | Samsung Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
HDMI quit working with store bought DVDs
so you have to update a new firmware and then it will be ok
Dec 20, 2007 | Toshiba 52HMX84 52" Rear Projection...
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
How to hook up with new converter boxes
This TV has a Digital Tuner built in?
Unless you have some purpose I would use the internal tuner.
Anyway. Use the HDMI input to hook up the Converter and Component (Red, Green and Blue video) to connect the DVD. You can use component for the Converter as well since it is reasonably comparable to HDMI (HDMI is 1080P Component is 1080i but it is difficult/impossible to notice unles picture is 60 or larger)
Jun 22, 2009 | Televison & Video
You need to go through the Setup in Media Center. Open Media Center. Click on "TV and Movies" and then "Set up TV"
Good luck.
Mar 19, 2009 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
We have just bought a samsung dvd r155, we are having great difficulty in connecting the dvd to the tv via a hdmi cable. Both the tv & the dvd have hdmi ports. When the tv is receiving the digital output...
In order to record on the DVD-R155 you need to be subscribed to Cable or Satellite and have a set-top box with the audio/video plugs and not just a coaxial cable from the wall. With just the cable from the wall you can only play DVD's. I have an older TV and need to change to channel 91 in order to play a DVD
Oct 12, 2008 | Televison & Video
Grainy Picture Denon 1740 DVD and Samsung 1080P LA40M81BD
Firstly, you should alter the picture settings on the TV. Most TVs have independant settings for tuner, scart and HDMI, so you may need to do this several times. Once for each.
Excessive contrast and/or sharpness on an LCD causes graininess, particularly around the edges of moving objects.
Check and adjust the following on the TV:
  • Contrast - about 65% max
  • Sharpness - 20%
These settings are a % of maximum, so you may need to work out a value if max is not 100.
Also turn off any contrast enhancements - (Contrast + / Digital
Contrast etc.) dependant on make.
I assume that you are using the upscaling facility of the Denon 1740 via an HDMI lead. If so, disconnect any other connections between the DVD and TV, particularly scart. If the scart is connected the TV will auto-switch to the scart input when you use the DVD, and you will not get the benefit of the high def connection.
This is probably obvious, but make sure the DVD is set to 1080p scaling, and you will need to manually select the HDMI input on the TV.
May 08, 2008 | Televison & Video
Plug and play on samsung r155 and samsung tv connected to v+ box by hdmi
I HAVE THE EXACT SAME PROBLEM WITH MY SKY + THE DVD PLAYER JUST FINDS NO CHANNELS - DID YOU GET A SOLUTION YET
Nov 20, 2007 | Samsung DVD-R155
Gateway FPD2485W Television Logo
122 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
