Do as follow to make your computer work like jet..
go to start menu
RUN>type REGEDIT>HKEY_CURRENT_USER>CONTROLPANEL>
DESKTOP>in that u will find MENU SHOW DELAY
set its value to 0 form 400
open run type TEMP and delete all files
open RUN type PREFETCH and delete all files
slow only on internet or off that too.
tell when it is slow doing what, and when not slow.
all PCs are slow. compared to better PCs and Better ISP.
I will answer for slow all the time.
1: normal , old PC.
2: hdd bad and runs slow. (replace it)
3: OS unstated by you is infected, reload the OS fresh.
<span>Computer running slow? Nothing is more frustrating than a slow computer. Speed up your computer now with our proven computer optimization service. As a leading Microsoft® Partner in the online computer repair industry we have access to the latest tools and resources from Microsoft® and others to </span><span>speed up computer</span><span>, </span><span>computer running slow</span><span>, <a href="http://www.mycomputerexpert.com/speed-slow-computer.php">fix slow computer</a> and Netbooks running Windows 7, Vista and XP.</span>
Are you still looking for a proper computer repair solution for your slow computer? Well, to repair your slow computer, you can follow these easy steps and make it run faster again in just minutes. You do not need to purchase a new computer to replace the slow one.
Another computer repair solution is to disable unnecessary Windows services and remove programs on the startup. How long does your computer take to enter the whole system? My PC boost up time is less than 30 seconds normally. By typing msconfg in the start-run menu, you can get to the right place to disable unnecessary Windows services and startup programs. This computer repair method can speed your slow computer up.
To repair computer slow problem, you also can update the device drivers regularly. There would be some conflicts among those outdated device drivers and that is the reason why you often get blue screen of death. If you want to repair and avoid system errors such as blue screen of death, system boost failure, don't be lazy to update device drivers in your computer.
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.
After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
A computer running slow down for many reasons, but most of those boil down to one thing - how do you use it. If you are experiencing this issue, you are not alone, nearly half of the complaints received by computer repair technicians were related to poor system performance or system slow down. Here are the top six reasons why your computer is performing slower. Read this blog to know more https://antivirus.comodo.com/blog/computer-safety/6-reasons-why-pc-running-slow/?af=9557
hi Jamiekom. Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance. Why is computer so slow to startup?
My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM Computer running slow at startup Check out this Quick Tip My Windows computer boots up slow computer slow on start up Google Search
It is possible that your computer is simply overheating causing it to slow down. There are a few ways to check this. Enter the BIOS and go to the hardware monitor, what temperatures does the computer read both for the CPU and the Motherboard? Another option is to install and run a program called HWmonitor that can be found here. Report back when you can.
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers. Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors. If you had trace to that problem, then replace the whole unit of hub connectors.
