Question about Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 continuous printing problem
First page prints fine but the following pages have content shifted down thus spilling to the next page
  • 2 more comments
  • Anonymous Feb 07, 2008
  • mohammedf Mar 02, 2008
    I am using Epson LQ2180 printer inwhich unable to get the print page by page only the first page is printing fine.
    kindly send me the solution for the same.
  • Syed Osram
    Syed Osram Apr 16, 2008
    I also having the same problem, first print the top page is at the correct distance but when the printing going down to the next page its slowly get down the page ? Setting is correct, page length 11" . Already adjust top page margin and tear off margin for continuous printing. So what is all about ?
  • Anonymous May 27, 2008
    Novelist:
  • 110 Answers
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
Posted on Aug 22, 2008
  • 37 Answers
Check your printer setup
Posted on Feb 05, 2008
Page sskip not working
I really don\'t understand what you mean by skip on the LQ 2180 dot matrix printer... Could you explain further. Waiting for your responds as to helping you resolve this issue.
Regards
Hope to hear from you soon.
Dec 03, 2013 | Epson LQ-2180 Dot Matrix Printer
Epson lq-2180 printer paper out & pause Indicator continously on
I have epson lq-2180 printer with the following problem: Paper out & pause indicator is continously on when I try to print. The paper is rolling when I push pause button.
Jan 22, 2013 | Epson LQ-2180 Dot Matrix Printer
Printing skips on the earlier page ? give me solution
Please check the Print properties.
mention the pages you want to print
then continue with the printing
Feb 04, 2012 | EPSON LQ-2180 ESC/P 2
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Mar 09, 2010 | Epson LQ-2180 Dot Matrix Printer
My lq 2180 printer is not aligned properly.printing starts 2 to 3 inches from start of page.jump in every next page is increased by half inch.kindly guide Thanks
Dear user,
please check the paper size and the procedure is below.
open printer properties and then go to the printing preferences and then there slect there appropriate paper size according to your paper being used in printer.
hopefully it will work perfect.
Sep 03, 2009 | Epson LQ-2180 Dot Matrix Printer
Epson lq-2180 printer pause light continously on
if u use up tractor use down tractor or inverse the operation
coz your problem is in paper sensor in up or down printing
Jan 09, 2009 | Epson LQ-2180 Dot Matrix Printer
Page setup
see the paper length you are using
ex. 8.5 X 12 "
set the paper length programatically by using following command
?? chr(27)+chr(67)+chr(0)+chr(12)
Jan 09, 2009 | Epson LQ-2180 Matrix Printer
Speed of print
A printer is designed to print at a certain ppm (page per minute), so really there is only one way to speed it up. When you select the print option from the File menu, you can select properties and see if you can change the dpi (dots per inch) of the document. Your document will print faster but you will lose quality.
Nov 27, 2008 | Epson LQ-2180 Dot Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Lq-2180 continous blinking
Please read through these instructions first and then follow the steps below:
1. Please power the printer OFF.
2. Remove the printer cable from the back of the printer and remove all the paper as well.
3. Hold down the "FONT" and "TEAR OFF" buttons and turn the printer on.
4. Continue holding the "FONT" and "TEAR OFF" buttons down for five (5) seconds and then release both at the same time.
5. Power the printer OFF.
6. Reconnect the printer cable.
7. Reinstall paper and ensure the thickness selector is in the correct position and that the path selector is also correct.
If the situation persists, remove the ribbon and paper and slide the print head back and forth so that it makes contact on both sides forcefully enough to make a loud noise. Reload the ribbon and the paper and try your test again.
Dec 07, 2007 | Epson LQ-2180 Dot Matrix Printer
Epson LQ-2180 Dot Matrix Printer Logo
2,160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
