Question about Refrigerators
Thermostat (1) Assembly defrost, (2) damper, (3)Thermostat???
Even with the thermostat set to the lowest number, it is too cold to keep food in the refrigerator. ie: vegatables burn (frost) milk contains ice etc.
A simple guess would be Thermostat. Faulty/bad connection/ broken
how do I identify which thermostat part I need to order??
  • jute Feb 06, 2008
    Thanks mate, post the results soon I hope.
  • Anonymous Apr 30, 2008
    I have a U-Line combo 75FF. The compressor runs all the time and freezes everything. Thermostat bad?
It may be the damper between the freezer and the fresh food (FF) compartment.  If it is stuck open, the cold air from the freezer is able to keep circulating into the FF compartment.  The GE side-by-side models have the damper located in the back of the FF compartment, upper left side behind a plastic shield.
Posted on Feb 11, 2008
  • 236 Answers
If it is digital control its either the thermistor or the control itself, if it is manual then the problem is the thermostat.
Posted on Feb 05, 2008
Shutting the freezer off and still having the fringe on
Sounds like you have two different problems. 1) If the freezer is freezing up on the lowest setting, sounds like your thermostat is bad. As the thermostat is a passive device it should open the contacts and turn the entire fridge/freezer off when satisfied (temperature set is temp reached). Sometimes the thermostat will get stuck and not turn off. If you can get to the thermostat remove it (plug pulled out from wall,PLS) turn the dial/knob slowly you should hear a click, if not give the thermostat a tap on the side a few times. Sometimes this will unstick the contacts. If not replace thermostat (can be costly) I suggest you check it with a meter before replacing. 2) It also sounds as if the defrost timer maybe stuck or defective, the defrost thermostat, in the freezer may be bad and/or the defrost heating coil. All of these parts are easily checked with a meter, once you find them. You will need to defrost the freezer first.
You didn't mention what brand of animal we are working on. If it is an Amana or similar they have a damper between the freezer and the fridge which is thematically controlled. They all go bad and when they do they shut (usually) trapping all the cold air in the freezer and everything in the fridge is warm. If this is the type you have find the model number look up the freezer damper part # and replace it, however first remove it and see how the freezer reacts. For if the thermostat is indeed defective the compressor will run continuously and you will freeze up non the less.
By the way, there is no way to turn off the freezer and use the fridge only, as they use the same coils and compressor! If you have 2 settings one for the freezer and one for the fridge all the freezer control does is open and close the damper door, as per the temperature setting.
Hope this helps, good luck.
Aug 10, 2016 | Refrigerators
Is there a recall on Kenmore coldspot model# 10671192100 mfg date 01/02? it doesn't keep food in the frig cold.
Check out the self defrosting mechanism on unit. could have a bad defrost timer and/or defrost element. Also check the damper control that sends cold air from freezer into the refrigerator compartment. If set too low your refrig will be warmer. Also check the thermostat setting and operation.
Jun 21, 2016 | Kenmore Refrigerators
Refrigerator freezing food
Let's start at the easy part. The thermostat should be set mid range if a dial thermostat. For example, if scale on thermostat is 0 to 9, set to 5. This is the most common problem and solution. If refrigerator is frozen, you may need to defrost unit by turning off and let thaw until unit is defrosted.
If you have a refrigerator with a damper, the damper could have broken off and the circulation fan in the freezer is circulating cold air continuously. To get part go to searspartsdirect.com with make and model number and get drawings of various systems. You can order parts and get them them in couple of days.
Hope this helps!
Apr 19, 2016 | Maytag Refrigerators
Even on lowest setting, drinks too cold, freezing at back, ice.
Thermostat needs replacing. Can`t find one online but I would guess a standard Danfoss would do it.
Mar 18, 2016 | Whynter Beverage Refrigerator
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
I have an Amana AFI2538AEW. Most of my Vegatables in the crispers are freezing and a bottle of milk in the back is frozen also on the shelf. Can you help me?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 30, 2011 | Amana AFI2538AE (25.6 cu. ft.) Bottom...
Just recently, even at the lowest settings (to keep temps warm as possible) the refrigerator is so cold the milk and OJ is freezing. Any advice on what might be the problem?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Kenmore Side by Side Refrigerator
Refrigerator side is too cold even with thermostat on lowest settings
heatman101
Jan 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Freezer works fine but no cold in refrigerator
Because Your model has an adaptive defrost board Part number Click Here=> 241508001 it is the most likely reason for the defrost or not cooling problem. Frost or snow will be collecting on the freezer walls. Click Here=> Frigidaire Controls FRS6LF7JW3 number 23 is the adaptive defrost and 115 is the auto damper and I need you to make sure it is opening and closing properly. This refrigerator is a little complex because the thermostat, auto dampre and Adaptive defrost are all wired together so don't give up until we locate the one of the three causing the problem. setting warmer freezer should open damper and cause colder fresh food. Stick with me on this. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Click here=> Wiring Diagram note wire 6 goes to auto damper so if ADC board or a thermostat defevtive that will be the cause.
Mar 24, 2010 | Refrigerators
Refrigerators Logo
394 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
