Question about Western Digital Caviar WD400JB Special Edition 40 GB Hard Drive
No hdd found...
I have recently purchased a 3.5" dvr digital videoplayer/recorder. Once I received it, I found it had no HDD at all. After re-checking the fine print, I discovered it was never meant to come with and that I was to supply my own. I contacted the company and I asked if any 3.5" IDE HDD would do; they said yes. So I purchased a Western Digital WD400JB 40GB IDE HDD, which I received today. I followed the manual and installed the HDD into the case as directed. When I connected it to my laptop via the USB cord provided it found the new hardware but within seconds had disconnected it and stating there was a problem with installation. I then connected it to my tv via the av cords provided. It brought up the display then began loading but again it brought up a message stating no hdd found. Can anyone help???
  • ceelaundry Feb 06, 2008
    Jumper settings on HDD needed to be set to master.
    Brigadier General:
  • 6,966 Answers
Hi.
Most new hard drives are not partitioned nor formatted and therefore are not ready for use when first bought. They have to be initialized/prepared for whatever device they will be attached to. Formatting may be FAT, FAT32, NTFS and others.
This could be done using a PC where the hard drive (HD) could be initially/temporarily installed as a secondary master/slave and use the Operating System to partition and format making it ready for use. Alternately, an external casing with USB interface may be used.
For your purpose, you need to determine in what format will your digital video player/recorder accept the new HD. This may be found in the manual. Alternately, some digital video player/recorder has this feature/option that will allow you to format newly attached to HDs.
Should the above be not sufficient, please post back with the brand and model of your digital video player/recorder.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 05, 2008
  • 37 Answers
Try another HDD
I can#t access the guideplus
Go to the hard disk setup menu.
Chose initiolized HDD, same as picture below.
Sometimes this can fix the problem.
Regarding the firmware, I do not think there is any firmware update available for download for this unit.
I did not find any download for your product.
Often, the image disk is distributed only to qualified repairers.
Sep 24, 2008 | Televison & Video
Can you record from a smart tv with arecording box
First of all you need to check if your TV supports recording. Some 2010 models do and most 2011 have it implemented. Look for stickers or logos such as:
  • USB Recording
  • PVR (Personal Video Recorder)
  • DVR (Digital Video Recorder
  • The following manufacturers support it in some of their models. Typically mid-end to high-end models. Check the manufacturer web site if you are unsure.
  • Samsung
  • Sony
  • LG
  • Philips
  • Panasonic
  • Toshiba
  • Sharp (only Time Shift pausing)
  • Grundig
    What you need
    Many consumers have USB recording enabled TVs without actually using the function - simply because it requires an extra USB hard drive ou need the following:
    1. USB Recording: A HDTV that supports recording.
    2. A USB HDD: FlatpanelsHD uses a USB HDD from Transcend.
    3. Digital channels: Recording is only enabled on digital channels - not analog. You can record SD, HD and 3D.
    Some manufacturers recommend USB hard drives with external power supplies but we have used a Trandscend USB HDD that takes power from the USB plug on all manufacturers' TVs without any problems. Manufacturers typically allow 1:1 recording, meaning that you will see no loss in picture quality.
    How to set up USB Recording
    Once you have purchased a USB hard drive and connected it on the back of the TV you can move on to "pairing" the USB HDD with the TV. Here is how to set up USB recording.
  • Connect the USB HDD to a free USB port on the back of the TV.
  • The USB hard drive now needs to be formatted (all data will be deleted).
  • Most TVs help you to format the USB HDD automatically but on some models you need to enter the menu and select format HDD (or something similar)
  • Sep 29, 2016 | Televison & Video
    How connect Magnavox DVDR to Comcast Cable Box ?
    You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
    Sep 25, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
    Does not record programes
    Most likly there is a problem with the HDD on the DVR if that is what you have DCT look like DVR's but do not have a HDD; If this is a DVR you will need to call you're provider or the manufacture of the DVR and have them Trade out the DVR; Never open the DVR and try to replace the HDD you're self you will damnage the box byond repare;
    Aug 27, 2011 | Televison & Video
    Connect satellite receiver to dvd recordrer
    there is really no way around it. Directv and Tivo are releasing a new receiver in a few months. Or you could purchase a HD dvr. Directv's receivers dont send any guide data thru a RF output, only picture and sound. The recorder you have is great for cable.
    Jan 06, 2009 | Televison & Video
    Set HDD to master
    The internal power supply to the HDD is often suspect in these units. Check you have power on the internal plug to the HDD from the circuit board. if you do not Try fitting an external HDD power supply (£15) this cured my unit which had a similar fault.
    Hope this helps - good luck.
    Jul 23, 2008 | Swann Communications DVR4-Alert Video...
    HDD Error
    Since my last post, I have rectified the problem.....
    1) I opened the unit to find a seagate HDD
    2) I downloaded the Seatools in dos format and burned the image on to a cd rom
    3)Taking out the HDD from my recorder,I hooked it up to another pc and ran the seatools disk @ bootup.
    I tried for 2 hrs to repair the bloody thing ( 160 gb!) so i gave up and tried to erase the full HDD...which worked.
    4) on my laptop i navigated to Pioneers site and found my recorder along with instructions and a zip file that contained 2 files.
    5)After reading the destructions erm i mean instructions ;) I put the HDD back into the recorder and followed the instructions again..
    Crossing my fingers i turned the recorder back on and to my amazement i was able to have more functionality..BUT... it says my HDD name error so I ran the disk again and wallah! all worked XDDDD
    Here are the links
    http://www.pioneer.co.uk/uk/content/support/support/update/DVR.html check if your model is there.
    http://download.seagate.com/seatools/registration.nsf/desktop?openform Just add your email too download.
    I hope you fix yours XD
    May 05, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
    Digital audio problems
    Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
    Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
    Western Digital Caviar WD400JB Special Edition 40 GB Hard Drive Logo
    295 people viewed this question
    Top Western Digital Computers & Internet Experts
    Arora Singh
    Arora Singh
    Alun Cox
    Marvin
    Marvin
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
