Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows XP Service Pack 2 shows asms missing
I was installing Windows XP on a machine which later has Windows 98, after partitioning and later when installation started with graphics before asking for product key it prompted 'Fatal Error: asms missing' and the installation failed, and later when i tried to install win 98 it was successfully installed, kindly help me is it the problem of disc or problem of hardware.
  • 1 more comment
  • Anonymous Feb 16, 2009
    Installing WindowsXP Home Edition, the cd installed but after a restart I received an error message: The "asms" file on E:\I386 could not be found" or something to that effect.
  • mohanranga Mar 28, 2009
    i have same problem
  • Anonymous May 11, 2009
    se necesita el archivo asmd en cd de windows xp professional service pack 2
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Posted on Jun 06, 2009
    Genius:
  • 1,142 Answers
Plz go thru the below mentioned link..i hope it helps
http://support.microsoft.com/default.aspx?scid=kb;en-us;311755&Product=winxp
Posted on Feb 05, 2008
You're a lifesaver Maanita Chadha!
I Hooked up the said XP Hard Drive to another system. After, I went into Windows I copied the i386 directory to the C:\Drive of the XP system, shutdown my 2nd system, popped that XP Hard Drive into it's original system, and was able to continue my install.
P.S. You might as well copy the "C:\i386" path, because I had to paste it in about 20 times. Just thought I'd save people the finger cramps.
Posted on Jan 26, 2012
Please check with another XP CD.. if the same problem continues jus replace the CD DRIVE itself.. this will fix this issue.....
Posted on Dec 29, 2008
  • 146 Answers
It would be a disc problem
Posted on Feb 06, 2008
:Error: the vc8 runtime Redistributable package was not installed successfully. Setup cannot continue
The Microsoft Visual C++ 2005 Redistributable Package (x86) installs runtime components of Visual C++ Libraries required to run applications developed with Visual C++ on a computer that does not have Visual C++ 2005 installed.
This package installs runtime components of C Runtime (CRT), Standard C++, ATL, MFC, OpenMP and MSDIA libraries. For libraries that support side-by-side deployment model (CRT, SCL, ATL, MFC, OpenMP) they are installed into the native assembly cache, also called WinSxS folder, on versions of Windows operating system that support side-by-side assemblies.
System Requirements
  • Supported Operating Systems:Windows 2000 Service Pack 3;Windows 98;Windows 98 Second Edition;Windows ME;Windows Server 2003;Windows XP Service Pack 2
  • Required Software:
  • oWindows Installer 3.0 Windows Installer 3.1 or later is recommended.
  • Disk Space Requirements: 6 MB (x86)
File Name: Size: vcredist_x86.exe 2.6MB Download
Jan 05, 2011 | Sony Computers & Internet
Tip
Upgrading Windows XP
Most users of Windows XP are using Windows XP service pack 2.
You can upgrade Windows XP service pack 2 by installing plain service pack 3.
This will upgrade and improve functionality to your current installation to Windows XP.
There are alot of versions of Windows XP Service pack 3 but i recommend downloading an official version from Microsoft's downloads center through the link below.
To after download is complete, install the file. Installation takes about 10 to 30 minutes depending on your system specifications.
If your current installation of Windows XP has too many errors, installation of service pack 3 may not be successful.
The solution to this is to reinstall your Operating System (OS) using your OS installation CD, then install Service pack 3.
How ever, OS re installation will erase all your data in your system partition so back up all your data.
To download an official copy of Windows XP service pack 3, follow this link:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
on Jan 07, 2010 | Computers & Internet
I am running Windows 98 Second Edition and am trying to upgrade my Internet Explorer. Any Ideas?
You have not mentioned the current version of your internet explorer.
The Internet Explorer 6 with service pack 1 was the last edition that can run with Windows 98/98SE/ME
IE6 with service pack2 (the service pack can be installed separately) requires Windows XP or later.
So If you are currently on IE5 you can upgrade it to IE6 and install Service pack 1 after the upgrade. You cannot go beyond IE6 SP1 with Windows 98.
Oct 26, 2010 | Microsoft Computers & Internet
I have installed windows vista and when i try to install nero burning software 6 and nero media player message is displayed it is not compatible with this version of windows what should i do
General system requirements
  • Microsoft ® Windows 98/98SE; Windows 2000 (service pack 4 or later); Windows XP; Windows 2003 server
  • Microsoft® Windows XP Professional x64 Edition (All applications beside InCD and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run)
  • Microsoft® Windows Internet Explorer 4.0 or later
  • LightScribe support is only available for Windows 2000 (Service Pack 4 or later) and Windows XP or Windows MCE 2004 or greater operating systems
Current version is 10. There are a lot of driver differences between XP & Vista. I'd buy the new version. You could try compatibility mode but I suspect it won't work.
Aug 05, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
I want to format my pc and fix xp service pack 2.how can i will be able to do this???
Hi, before you format your hard disk, make sure you have saved all important files that you like to keep on an external drive, for example a USB Stick. Formatting your hard disk will destroy all data.
If you want to format and reinstall Windows XP do the following:
Insert your Windows XP CD. Restart your computer. Your computer should then automatically start from the CD and show the Windows XP Setup.
In Windows Setup you can choose the partition on which you want to install Windows. There you can also format the partition, before installation. To do this, just follow the directions that are shown.
Jul 12, 2010 | Computers & Internet
I can't install it.
Ensure that you are running XP Service Pack 2 version, this software won't work on Windows previous version.
If you are using 98, you need to upgrade system.
If you are using XP you may need to upgrade service pack 2, see Download details: Windows XP Service Pack 2 .
Jan 04, 2009 | Sony Vegas Movie Studio Platinum 8
I re install my windows xp and after half of my hard drive are missing before it was 450 GB and now i see only 255 GB
have you created partitions before installing XP?
if not then i request you to please first create partitions the way u want then try installing xp
Nov 14, 2008 | Computers & Internet
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Hard drives not detected
you should repartition your hdd. using disk manager, 1st step. do zero level, then low format. after doing those step. make partition and install your os. good luck
Sep 08, 2007 | Microsoft Windows XP Professional With...
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
9,091 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
