Question about Protron PD-DVR100 DVD Recorder
Power malfunction My protron dvd recorder display lights were all flashing, and the  unit wouldn't respond to pressing any buttons.  I unplugged power, and when I re-plugged it in, no display showed, and power will not turn on.  What do I do?
  • 1 more comment
  • nald90 Mar 20, 2008
    Unit is dead. Power board has 1 bulging capacitor. I have not tried to put power directly to the drive to check it.
  • boomerinsd Apr 11, 2008
    I have the same problem as the previous post, what are our remedies? Is there anything through the company we can get a replacement?
  • bigabie May 30, 2008
    same as stated
    display flashing turn of now will not turn back on
Can we get power supply
Posted on May 30, 2008
I think these are just junk unfortunately. I have tried multiple times with a reset problem on mine - I think these just have faulty power supplies?
Posted on Feb 28, 2008
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
I incorrectly entered PAL in video format setting now screen is stuck and says change resol utio n but can not change it need help!!! protron pd-dvr100 dvd recorder
I'm sorry for the difficulties you're experiencing as the Video output settings on the DVD Recorder is set incorrectly. Please perform a power resetting by following the below steps and check the operation.
To perform power resetting, unplug the DVD Recorder from wall outlet for more than 5 minutes and press and hold the Power button for more than 15 seconds. It will discharge power from all circuit and move the Recorder to factory default.
Thanks for understanding. Please let me know if the issue persists.
Nov 23, 2011 | Protron PD-DVR100 DVD Recorder
Panasonic DMR-EZ48V stopped working properly. It seems to have frozen up, but resetting it doesn't get it working again. When I reset by pushing the power button for 10 seconds, it flashes HELLO 15...
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
Jan 23, 2011 | Panasonic DMR-EZ48 DVD Recorder
Where do I find codes for Protron DVD recorder PD-DVR 100 for a Dish Network remote control
I hope that you have found the codes by now, but if not, here are the codes we have, and also the steps to program that remote.
1. Hold down the clear AUX button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the DVD on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
685 is the only code we have for this brand.
Becki Barned
DISH Network Customer Service
Sep 19, 2010 | Protron PD-DVR100 DVD Recorder
Power button flashes SAFE
I unplugged the unit for 30 minutes and it finally went out of safe mode.
Oct 12, 2008 | Televison & Video
Protron pd-dvr100
Fixed mine by opening up and replacing ide cable to the DVD burner. Was flashing hello. When opened up and touched the ide cable it would spin up the drive for a second. Its possible it was loose connection to the power plug in the drive but replaced ide cable just in case. Has been working perfect since. Very roomy inside and easy to do.
Feb 08, 2008 | Protron PD-DVR100 DVD Recorder
DVD malfunction
Check to see if there is power first second if there is unplug unit take off the lid and try using a can of compress air. and thoughly spray behind the face plate if notice any dusts particles behind the face plate carefully remove by flipping clips and use 100% rub alconol which can be bought at the drug store. Then allow drying tme. the buttons may be worn or clogged hope this helps
May 28, 2007 | Cyberhome DVR 1600 DVD Recorder
PD-DVR100 DVD Tray will not open
Hi Mikey We are having the exact same problem with our recorder. Don't know if it will work for you, but we turned it off and while it was saying hello, my husband kept pushing the open button and it finally opened. We recorded a movie last nite, and it wont do anything, just keeps flashing PrOce on the player screen. I called the 800 number and he told me to unplug it too, that it would reset itself. It's pretty bad when you spend $300 on something and it only has a 90 day warranty, and then they expect you to just take it to a repair place and have it fixed yourself. We will never buy a Protron product ever again. Guess we just have to go buy a new one, since they wont help on this one. If anyone else has any suggestions, please help us out. Thanks, Becnfiat
Jan 02, 2007 | Protron PD-DVR100 DVD Recorder
Protron PD-DVR100 DVD Recorder Logo
125 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
