Question about Tomtom One Europe v2 GPS Receiver
Tom Tom no sound
My Tom Tom one has no sound.
I have checked it is not muted, adjusted the volume, selected other voices and tested these voices. There is audible tick from the speaker when I test the voices Hope you can help
  • 3 more comments
  • Anonymous Feb 26, 2008
    my Tomtom was working perfectly for the past year, and all of a sudden the sound has dissapeared, i tried to change the preferences and change the voice and everything and did not work, i reset factory settings still did not get it back any tips?!
  • flatflor Mar 01, 2008
    same problem with sound. recently just updated tt .
  • dgdunn1 Mar 06, 2008
    I sent of to TomTom they suggested using the reset. It worked.
  • stoko2008 Jun 17, 2008
    The sound on my Tom Tom One suddenly stopped working.
    I checked the preferences to make sure that it was not muted and then pressed the reset button but this had no effect. I've tried different voices but still no sound.
    Any suggestions?
  • gibbsy17 Nov 16, 2008
    I have no sound and volume 100 up and speaker is on and i tried to resert it and its the same i have changed voices and sound and i test it there no sound
Let the battery get full charge.
Take the SD off.
On the bottom push in the RESET at least 15 SECONDS.
(It will go off, but it is resetting)
After that press the POWER ON for 5 SECONDS
Put in back the SD card.
Done.... easy!!!!!
Posted on Oct 02, 2009
Plug your TT into computer and open device. Check to see if you have a folder called 'LoquendoTTS' ,if so copy it first to your computer then delete from TT. This folder contains the computer voice for reading out street names, seems to get corupted. This cures all sound problems ive encountered.
Posted on Dec 04, 2008
A hidden shortcut to the volume bar is available on the main screen of your TomTom. To access the volume bar simply tap in the lower-left corner when in the navigation view:
Tap on the volume button and move it left or right to change the volume.
Posted on Jan 20, 2010
I too had no sound from my tomtom one xl. I was out of any warranty so i checked for voltage output at speaker terminals with a DVOM. I was getting a signal to the speaker. Mouser electronics at www.mouser.com sells generic speakers. I used #253-2040cp08-ro Kobitone speaker for my oneXL. Replacement speaker works perfectly and spent under $5 dollars. (Note: You must solder the wires to the new speaker, so some mechanical ability is needed.)
Posted on Mar 09, 2009
  • gca radar Oct 04, 2010
    Good job Mark! I pushed in slightly on the speaker and selected the volume test. Speech came thru while I did this. Just ordered a replacement from Mouser. Thanks for doing the leg work researching the replacement. I looked at the UK site for a replacement speaker and the price was outrageous.
    Terry
No sound is a common problem on tomtom ones.
Usually changing the speaker does the trick.
try url below, they have spare speakers for this unit.
www.callconnectsystems.co.uk
Posted on May 31, 2008
I conect my tomtom to my laptop, charge it,
and close it, and then restart it, it recovered!!!
I don't know why, just wanna people try yours.
Posted on Jun 26, 2009
Try it with headphones
Posted on Mar 22, 2009
  • 1finfulham Mar 22, 2009
    TRY IT WITH HEADPHONES
Send it for repair
Posted on Mar 09, 2008
My fault developed as intermittent sound before the audio finally died. My solution for my TomTom One may sound crazy but worked a treat.
I removed the defunct speaker which is encased in a plastic surround held in situ by soft rubber mouldings. I then replaced it with the speaker out of a McDonalds toy that comes packed with cheap ‘Chicken Nugget Happy Meals.’
The audio was quieter but very clear, and I think this was down to the fact that the Tom Tom speaker is 4 ohm impedance whereas the toy was 16 ohm impedance. However I resolved that one by inserting another, wired in parallel and it works absolutely great! The dimensions are precise for two to be sat side by side and held in place by the soft rubber mouldings.
Best regards
filibuster
Posted on Jul 19, 2010
  • inkblot629 Feb 05, 2011
    The sound on my Tom Tom stopped working all of a sudden one day as well. I finally got it going again by putting the tiny manual reset button the bottom of the device (different from resetting the factory settings on the touch screen). Hope it keeps working!
I had a similar problem where the drums would play at the beginning but no driving sounds. I finally realized it was the FM Trasmitter. I turned it off and got my sounds back.
Posted on Aug 12, 2008
Send it for repair!
Suffering from same problem with recently purchased TT. Apparently its ahardware fault and should send TT back for repairs
Posted on Mar 05, 2008
Sound is muted. How do I get the sound back?
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
Feb 21, 2013 | E-Machines eMachines Desktop PC
Toshiba a215-5837 internal microphone not working
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or
also
click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in
W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or
you might have to boost
hope this helps
Jun 25, 2012 | Toshiba Computers & Internet
Sharp laptop mic problem
which message program skype or yahoo messenger .........
will need to know to find out settings for a mic
click start control panel sounds and audio devices audio and also voice its the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
hope it helps
Apr 17, 2012 | Sharp Computers & Internet
The microphone wont work on my laptop
also
or
hope this helps you
Mar 22, 2012 | Toshiba Computers & Internet
My sound card problem i am not hearing any voice
is this your earphones or speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 31, 2011 | Computers & Internet
1. no volume control for microphone sound 2. no windows sound wave
click start control panel sounds and audio devices you can adjust the volume there also select recording or playback you should find something there
hope this helps
Apr 30, 2011 | Computers & Internet
I'm trying to connect my headphone/microphone to my pc but no any option gets shown after connecting headphone to pc neither any sound is audible to headphone though speakers are working !
i dont think anything will show on your computer unless you are using an internet messenger program yahoo or skype or something similiar you will have to do this manually
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Apr 18, 2011 | Gigabyte Computers & Internet
How to download the audio driver foxconn ?
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 09, 2011 | Foxconn 661FX7MI-RS (661FX7MIS)...
How to adjust the volume? Volume is barely audible. Tom Tom 550TM
You can use the PREFERENCES menu option to change the volume of the voice instructions. Use 'Volume preferences' pref06.gif, with its sliding scale to set the required volume in increments of 5%.
The 'Test' function is a good way to get the volume right before starting your journey. You may also find it helpful to use 'Link volume to car speed', so that the voice instructions get louder as road noise increases and are at their quietest when you are stationary.
Jan 02, 2011 | Tomtom XXL 550tm GPS Receiver
People cant hear me
if you are using skype
open skype go to tools from the drop down list select options scroll to audio settings make sure the microphone is using the same as your computers audio you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment or control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make the right adjustments
or
control panel sounds and audio devices select advanced there might be a tick in the mute box untick or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Nov 14, 2010 | Computers & Internet
Tomtom One Europe v2 GPS Receiver Logo
15,965 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
