Question about RCA F36648 36" TV
RCA-f36648 my cable input adapter broke off and i ran it through an rf module and i cant get a signal,why?
  • kidrockterry Feb 05, 2008
    THANKYOU LADYWINN,I am trying to do what you said with a toshiba vcr,It tells me to put the vcr on ch-2,which i do and it says it is configuring to vcr,iI follow the steps but it still will not accept a cable no matter what I try,It will play the vcr and the dvd player thru rca cable and the s-video cable I just cant get cable to work and I have checked my cable output could you please give me any more options to try,other than the repair shop? Thanks again
  • RCA Master
  • 5,138 Answers
How are you connecting up your tv? also getting new IF connector should not cost more then 100.00 at the most and thats to much .also what are you using for tuner source?you have to connect to vcr,satellite or cable box using externel jacks,use back av jacks yellow video- red&white audio,then you will be using channel 3 or 4 on tv to change channels thru your vcr,satellite,or cable box which ever one you are using for tuner.If you have it connected right your set should work.let me know if you need any more help with this.ThankYou for using FixYa and Have a Nice Day.
Posted on Feb 05, 2008
  • ladywinn
    ladywinn Feb 05, 2008
    ok, if what you are doing is not working try different av jacks maybe there is something wrong with your video cable connectors .Do you have another vcr that you can use,and if you dont have one, look around at goodwill stores ect...i have found them working for 5.00 I am wondering if thiere is something that is not switch on video in menu do you have different levels for video1 2 AV you might not have right video switched on
Trying to connect a DVD player to a TV that is only equipped with a cable jack what do I do
You need an A/V to RF adapter to convert the audio and video outputs of the DVD player to RF so that you can watch the DVD player on an available VHF channel on the TV. See this device offered by Amazon:
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
You may also need a short 75 ohm length of coaxial cable with "F" type connectors on both ends and A/V cables with RCA plugs to complete the setup.
Jan 02, 2015 | Televison & Video
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
I have an rca f36648 entertainment series tube tv. it has right white and yellow video input on the back that i attempted to plug my playstation 3 into however when i set it to the video input channel it...
It is compatible. The yellow cable is the video portion of the input and the white is the audio portion of the input. When you do this and switch the video mode or change the channel to number 3, it should work
Jun 08, 2011 | RCA F36648 36" TV
On the Dynex? - RF Modulator AV Signal Converter, the RCA plugs on the back, are they input or output?
Input. The intent is to convert Composite Video, S-video and audio from newer devices to old TV's that only have RF (antenna) inputs.
May 03, 2011 | Dynex RF Modulator AV Signal Converter
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
DVD to TV - can't connect. No inputs on the actual TV
You could buy a RF Modulator, into which you can Input the 3 cables (Video, Audio Right and audio Left) and the Modulator will make it into a single RF signal, which can be tuned by the TV. RF Modulators are generally set at UHF Channel 36 by Default. One of the easisst available is the Rabbit Ears Modulator, which "transmits' the signal wirelessly to the TV. Not more than 15-20$
Nov 29, 2008 | RCA 32F531T 32" TV
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Nov 08, 2007 | RCA F27242GY 27" TV
RCA F36648 36" TV Logo
102 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
