Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
2nd laptop I need to connect to the internet on a 2nd laptop through the same wireless router
  • 38 Answers
No problem, if the laptop has a wireless network card, then just have the laptop search for the wireless router and connect. If the router doesn't have a wireless network card, but does have a wired network card, just plug it in to an available port.
If you have any questions or issues, please post them with as much detail as possible so we can help get thing fixed!
Posted on Feb 05, 2008
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
What steps do I take to allow my 2nd computer, a laptop, wireless connection to internet through my WGT624 wireless router?
>Switch on your laptop wireless..
>Goto Network sharing center from network connection settings menu from control panel..
>Search for New Connection and select your Wifi router And mark it as shared..
Aug 14, 2009 | NetGear WGT624 Wireless Router
Laptop can connect to wireless router but not the internet
It could be a conflict with IP adresses. Go to your network connections and right click on wirless connection and go to properties. Scroll down the list to internet tcpip and highlite it. Once highlited go to properties. Then check the set manual ip adress and set it to whatever number you like. leave the bars as is. Do the same to the other laptop but different number.
Aug 03, 2009 | Computers & Internet
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
Jul 31, 2009 | Computers & Internet
2nd laptop will not connect to internet
I'm assuming that your 2nd laptop is wireless? Does your router have encryption? If it has, then you need to get the encryption key from one of the working computers. Access the linksys interface from one of the working computers. Usually this is done by going to http://192.168.1.1 (leave username blank, password is "admin"). Go to Wireless> Wireless Security. Is encryption selected? If yes, get encryption key #1 and use it on the non-working laptop to connect to the router. If encryption is not enabled, go to the steps below.
On the 2nd laptop, click on the wireless icon at the bottom right part of your screen. Look for the linksys router from one of the available wireless networks, click connect and enter in the encryption key when it asks for it (not case-sensitive. Usually it's 10 or 24 digits). If encryption is not enabled, it will not ask for the encryption keys when you hit connect. See what happens.
Jul 05, 2009 | Linksys Wireless-G WRT54GS Router...
Laptop wireless computer on 2nd floor. Modem and
To test it whether the signal is too weak or not, take your laptop closer to where the router is and try to connect that way. If it does connect then the wireless signal from the router is too weak in which case get a range expander or purchase a router with extended range.
Mar 23, 2009 | NetGear WGR614 Wireless Router
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
29 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
