Question about Canon NP 6551 Black and White Copier
E210 Hi! I just encountered the subject error in my canon 6551. I really appreciate if you can help me. Thanks in advance.
    Problem Solver:
  • 6 Answers
E210 is a len home position sensor problen. When you turn the copier, the lens should move to the rear of the copier, and left to right also. It is commom for a little gear to break off in the gear box that is on the motor. Good Luck,I have been a service tech for Canon for 23 years.
Posted on Feb 17, 2008
  • 36 Answers
Error 210 means that the printer scanner hasn't returned in its initial position.
You should see there http://en.allexperts.com/q/Repairing-Copiers-Faxes-1748/Danka-Copier-Canon-NP6551.htm , it may help you.
Posted on Feb 05, 2008
E210
related to the exppossure system the lens does not return to itfs home position within the specified time fix its movemenet. expossure lens. The lens (camera) you must look for any-thin that might make its movement difficult in its rail. also check the sensor if properly positioned. and oil its path.
Aug 02, 2011 | Canon NP 6551 Black and White Copier
Errorcode E210 - What is the problem?
check the scanning cable and scanning lamp
Jan 07, 2011 | Canon NP 6551 Black and White Copier
Cannon 6551 Error message E210
This is most likely the lens motor is not working. The scanner should go left to the home position, then the lens should move all the way left to the lens home sensor and then go toward the rear of the copier to the home position sensor. If the lens doesn't go towards the rear then that motor is bad. There is a problem that the gear that is attached to this motor tends to crack and gives this error. You can see it clearly if you remove the glass. It will ahve to be replaced. It's been so long since I did one of these I couldn't describe how to remove the motor. Good Luck.
Nov 30, 2010 | Canon NP 6551 Black and White Copier
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
E210
scanning lamp / scaning area
Jul 23, 2008 | Canon NP 6551 Black and White Copier
Please help
E401 RDF Pickup motor or pickup sensor problem, try to clean the sensor and reset the error code in *4* ERROR clear.
Jul 08, 2008 | Canon NP 6551 Black and White Copier
Canon NP 6551 Black and White Copier Logo
306 people viewed this question
old marine
old marine
