Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Please help I don't know what happen to my calculator, but every time i open it there is always a gap in the middle and when I draw graphs there is a blue line on the axes. Please help me if you know how to fix it. Thank-you.
You must have dropped the calc at some point huh? Sounds like the LCD is broken. You can try resetting the MEM, but I doubt it'll work since these calcs don't have color displays and yours is showing a blue line. This leads me to believe that the LCD is broken. Live with it, have it repaired professionaly, or buy a new calc.
Posted on Apr 21, 2008
When I try to graph something, I see the graph, but I no longer see the x and y axis. This happened on my TI-89 titanium
Enter a function in Y= Editor, then draw its graph.
While the graph is still displayed Press F1
Press 9:Format to open the FORMAT screen
Toggle the Axes ON
Aug 26, 2011 | Texas Instruments TI-89 Calculator
I am using a casio graphing calculator and I am trying to graph a parametric function. I put the mode on Param and I inserted xt and yt and i press draw. It draw but then stops and gives me an arugment...
The argument error must have something to do with the parametric functions you are drawing. I do not think anybody would know where to look unless you give us the functions.
As to the range of the T-variable, you can set it by pressing [SHIFT][F3] to open the (V-Window) configuration screen. It starts showing Xmin, Xmax. etc. To get to the T range, use down arrow (about 7 times).
Dec 06, 2010 | Casio FX-9750GPlus Calculator
How to use graphing calculator?
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Aug 13, 2010 | Casio FX-300MS Calculator
I'm trying to graph a circle on my TI-83 Plus. 1.) I don't know the way to trick the calculator into graphing the circle 2.) When I try to graph I get 'ERR:WINDOW RANGE' I don't want to use draw and i...
Here is the link to post where I show several ways to draw a circle. If you do not have the conics applications download and instakk it on the calculator.
You can also use the cabri Jr application downloadable from education.ti.com. This application is dedicated to geometry.
Apr 10, 2010 | Texas Instruments TI-83 Plus Calculator
Having problem with ti 83 calculator everytime i graph it read error invalid dimensions
You must deactivate the statistical plots. If you do statistical graphs, the graphing is reconfigured in a way that happens to be incompatible with regular fuction graphs.
  1. To deactivate the statistical plots.
  2. Press [2nd][Y=] to access the (STAT PLOT) menu.
  3. Press [4:PlotsOff][ENTER].
  4. Calculator displays Done.
  5. You are ready to draw the function graphs.
Feb 15, 2010 | Texas Instruments TI-83 Plus Calculator
When I go to the y= menu I have \r1= and I dont know how to change that. please help
Your calculator is currently configured to draw polar graphs. To recover the more common Y= graphs,
  1. Press [MODE]
  2. Use down arrow 3 times to get to the line FUNC PAR POL SEQ
  3. Use left arrow to highlight FUNC and press [ENTER]
  4. Press [2nd][QUIT] to exit the MODE screen.
  5. Restart your graphing.
Jan 21, 2010 | Texas Instruments TI-84 Plus Silver...
Graphic calculator texas:when i graph any function, it always says "invalid dim"
A previous problem on statistics has turned the statistical graphs ON and that interferes with the graphing of functions.
TurnOff the STATPLOTS by pressing [2nd][STAT PLOT][4:PlotsOFF]. Command echoes on the home screen. Press ENTER. I was going to add to reset all ram just in case.
Make sure you are drawing the right type of graph. To check that press [MODE], scroll down to 4th line to highlight Func and press ENTER, if you are drawing y=f(x) functions. The others are PARametric, POLar, SEQuence.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
I dont know how to graph
Turn calculator [ON]. If you do not see the menu icons, press [MENU]. Use the arrow keys to highlight the [GRAPH] icon.
An entry screen appears where you enter the functions you want to graph.
On the first line you have Y1= . After the equal sign enter 2[x] [X, theta,T] + 1. When finished press [F6: Draw] Your graph appears on the screen. If you see the axes, but no graph, press [Shift][V-Window] and press [F3:Std] then [SHIFT][QUIT] will take you back to the screen where you enter the functions to draw. There press [F6:Draw].
Hope it helps.
Sep 21, 2009 | Casio CFX 9850GA Plus Calculator
Error 13 dimension
You were lucky not to see the dimension problem with the TI83Plus.
To get rid of the message, reset you calculator to DEFAULT configuration. It will erase nay garbage in the registers and you can draw your graph.
Hope it helps
Apr 02, 2009 | Texas Instruments TI-86 Calculator
I need to make a graph on my CASIO CFX-9850Ga PLUS
Hope it helps.
Jan 28, 2009 | Casio CFX 9850GA Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
149 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
