I have a 2000 sl2 saturn and a dash warning light keeps coming on. its a square box with an arrow pointing down with a wavy line at bottom of arrow. what does it mean?
Sounds like a low coolant indicator.
Is the car running hot? Check and top off coolant (Radiator fluid) but do NOT open radiator cap if the engine has run in the past hour. Most times you top off the fluid by filling seperate reservoir
your antifreeze is low . check you overflow container if its where it should be add a little anyway and see if the problem goes away if so the sensor is bad . another way is find the sensor and unplug it and see if the problem goes away . if its bad i would fix it if i where you its a handy little light to have
