Normal
0
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the
heater and put the other end a few inches down the drain. The heat convection
may prevent it from freezing.
Testimonial: "Super fast feedback!"
I appreciate the quick and thorough response! I apologize but I am a very novice and this is my first attempt at any repair. I am not sure what/where I need to be looking to find the drain tube to remove the ice and then flush with warm water? Is this inside the freezer itself? or do I need to go through the inside of the fridge or through the panels on the rear? Please help
Thanks!
Thanks!
