Question about Pioneer SD-P50A5-K 50" Rear Projection Television
No audio or video
I can see the channel and volume display but no audio or video. my tv is a pioneer projection tv model # sd-532hd5
    Brigadier General:
  • 6,966 Answers
If you can see the channel number as well as the volume setting when you press on the appropriate buttons on the remote, then it would seem that what happened is that your TV went into muting (video and audio). This can only be brought about if the TV is not receiving any signal from your cable or aerial. This is a built-in feature. Another possibility is that the tuner section of the TV has some issues. To determine whether cable or tuner, pls try installing a known operational VCR and play a good tape. Connect the RF OUT of the VCR to the CABLE/ANT IN of the TV. Select channel 3 or 4 and should you be able to watch the tap video, then you have just confirmed that it is your cable (or aerial). If on the other hand there is likewise no display on either 3 or 4, then you have just confirmed that somethings needs to be done internally in the tuner section.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 05, 2008
I have a model number sd-p503p-k i dont know how to add channels after channel 65?
You probibally need to re-scan your available channels. The TV goes through and grabs all of the available channels that it sees so you don't get any all static channels while your surfing the tube. The manual is actually about 35 megs so I cannot post it here, but here's what it says; - Hit Menu
- Select Setup
- Select Channel Setup
- Select Auto Channel Preset
- Select Antenna and change it to A or B, whichever one your using.
This should fix your problems, unless your area doesn't have channels past 65. If that's true then everything I just wrote is irrelevant, but there ya go!
Oct 28, 2009 | Pioneer SD-532HD5 53" Rear Projection...
I own a pioneer projection monitor model SD-532HD5. It has been flickering on and off where it goes from its crisp color to a hazy type picture. Yesterday, it flickered and the picture went away...
This TV is known for bad solder joints on the Power board. Call a good TV Tech and have him resolder the Power board. It is on the right hand side of the TV looking from the back.
Jul 30, 2009 | Televison & Video
Manual for Pioneers Flat Screen TV
Contact me I can get you a copy of manual for $25.00 Camale001@hotmail.com
Dec 15, 2008 | Pioneer SD-532HD5 53" Rear Projection...
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Off Screen Picture
There is a width problem. There could be a control inside to control this but the TV should not change so drastically. There is most likely a problem in the width circuit.. This is a high voltage circuit, and is very dangerous to tinker or experiment around inside of. Your best bet would be to call an Authorized Pioneer repair shop and have them have a look at the set. Good Luck
Jul 14, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Possesed awesome tv
the clicking noise is probably just the relay. I gyess it makes the same noise if ou turn it off manually with the remote? Does your TV have a sleep timer function? Check to see if this is enabled. You might also check the batteries. If they are old, or the battery compartment is dirty (leaking barteries etc) you might get strange behaviour. My remote lives a life of it's own, changes channels etc if the batteries are weak.
May 17, 2007 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-532HD5
it is time to buy a new one,,,sorry
Aug 23, 2006 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
52 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
