Question about Reddy Heater-30-55,000 BTU Variable
Reddy Heater RLP 30 ignites but won't stay on.
Hello, I have a RLP 30 forced air heater. It will readily ignite and stay on as long as I keep the other red button depressed. As soon as I let off that button the flame goes out.
  • splake Sep 06, 2008
    My reddy heater runs good as long as I have the pre start (heat) button pushed in. As soon as I let it go the burner goes out, even after holding it is for 5 min.
  • IDBigDog Oct 11, 2008
    I have a 35000 propane Reddy Heater and it too will only stay lit when the starter button is depressed. The expert said that it sounded like a Thermocouple, my question is: Is this something that I can order from someone and who would carry this part.
    IDBigDog
    Problem Solver:
  • 19 Answers
Sounds like a bad thermocouple.
Posted on Mar 05, 2008
My reddy heater RLP 100 would not stay lit after I released the ignitor switch so I changed the thermocouple and, the thermal unit switch. The heater will ignite but when I release the knob the flame goes...
A couple of things come to mind:
Restricted air flow. Check heater inlet and outlet. Remove any obstructions.
If the heater has been used in a dusty environment, it may simply need a thorough cleaning.
Inadequate propane supply. Make sure there's enough gas in the tank to facilitate combustion.
If the tank is full, turn of the tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve on very, very slowly, until it's fully open and try relighting and operation of the heater.
If you have misplaced your Owners Manual, you can find it at www.deastech.com
Hope this helps to solve your problem.
Mar 02, 2011 | Reddy Heater RLP100 Portable Forced Air...
Can i convert my rlp 30 to natural gas
No you can not convert this unit to natural gas. They do not make a conversion kit or give us any sizes to drill out any orifices.
Dec 27, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
R100 reddy heater, low pressure forced air heater. the heater ignites, motor runs for 30 seconds then shuts down. photo cell good, filters clean, no ignition board, pump pressure unknown.
The R100 is a kerosene heater and the RLP100 is a propane heater so I am not sure when one you have.
If it is kerosene then you may need to check the pump pressure. Also the Safety swith can give you a cut out after 30 seconds.
If the unit is Propane then you could have a bad control board or a flame sensor.
You can call our service department at 1-800-475-5660
Thanks
Oct 21, 2010 | Reddy Heater RLP100 Portable Forced Air...
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Rlp 30 won't stay lit after holding control button 30 seconds
Chk and make sure the thermocoupler bulb is in the pilot flame, If it is, it is defective and needs to be replaced. Easy, inexpensive repair. Good Luck, Ned
Dec 27, 2008 | Reddy Heater RLP100 Portable Forced Air...
Won't stay lit..
I contacted ReddyParts.com and talked with their support department (866-883-9312). They instantly stated "your thermal coupler is bad". They had 1 in stock for 19.99 + shipping. I ordered it and plan to have it installed and tested by next weekend. The model I have is Reddy Heater Propane 35k to 55k (RLP55V).
Dec 12, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
530 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
