Question about HP LaserJet P2015dn Printer
Help deer sir, i have a problem with hp l/j. 2015 when i takke it on the upper two leds will on after few second these wil off and down three leds wil on and printer is not redy. plese help me about this problem. I m thanks ful to you. Yours, Raja M.Afza
    Novelist:
  • 103 Answers
Hi Raja,
This means there is an error during POST (power on self test). Please refer your manual for the error codes or light codes. If you can manage to access the machine diagnostic menu please do. Like from off position and pressing combination of buttons holding for 3 to 5 seconds and powering it on.
Best regards,
Rosener
Posted on Feb 05, 2008
  • Talha Saeed
    Talha Saeed Dec 02, 2015
    its a hardware issue.Bad formator cord..
How do i charge up my fitbit?
      To charge your tracker:
      1. Remove your tracker from the wristband:
      2. Insert your tracker into the charging cable. ...
      3. Insert the charging cable into a USB port or UL-certified USB wall charger.
      4. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
      More items...
      Help article: How do I charge my tracker? - Fitbit Help
      https://help.fitbit.com/articles/en_US/.../How-do-I-charge-my-tracker Fitbit
    Feedback
    https://help.fitbit.com/articles/en.../How-do-I-charge-my-tracker
    FitbitDec 12, 2015 - To charge your tracker: Remove your tracker from the wristband: Insert your tracker into the charging cable. Insert the charging cable into a USB port or UL-certified USB wall charger. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
    Fitbit Help - Getting Started
Jan 21, 2016 | Exercise & Fitness
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
MY HP LED HD 23" screen goes black for few seconds and then goes back up again.
This is most likely the power inverter. It's a relatively small part but if it's not supplying power to the backlight, you won't see anything.
It needs to be replaced.
Mar 29, 2012 | Computers & Internet
How to set led watch
What make and model of watch is this?
Sep 08, 2011 | Watches
Dear sir My HP ProBook4510s showing a white screen with hp logo and "Select User to Login" but there is no option to select user. If i type anything and press enter key three times it is...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP ProBook 4510s FM849UT Notebook
When I want to print something, if I go to file then print, it says offline, bot when I click on the C4200 series( copy 1) it will print BUT brints VERY small. Am I supposed to doing something...
  1. Click start --> Control panel --> Printer and faxes
  2. Right click on printer 'C4200 series' and select 'Set as default printer'.
  3. Right click again on the same printer icon and select 'Use printer Online'.
  4. Try Printing.
  5. You can delete the icon that says 'C4200 series(copy1)' if you are not using it.
Regards
Riztech
Oct 24, 2010 | HP Photosmart C4280 All-in-One InkJet...
Vizio 42" plasma tv model#p42hdtv10a
yes,veryry possible you have a bad transister on the power supply board .best way to fix it is to change the hole board.
Oct 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Black screen covering most of tv screen at a few channels; a code appears at upper left corner. The black screen disapears for a few seconds if I turn the volume up or down at the remote control but it...
Turn off your closed caption and or text mode using the closed cation button on the Magnavox remote or through the TV's menu there wil be an option to do so.
May 24, 2008 | Philips Magnavox MS2530C 25" TV
HP LaserJet 3600dn Printer Problem The printer is new but wil not function.
In menus, diagnostic menu, "show event log". What error codes are listed?
Apr 12, 2008 | HP LaserJet 3600dn Printer
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
HP LaserJet P2015dn Printer Logo
176 people viewed this question
Ben Johnson
