Question about Panasonic CQ-VD7003U Car DVD Player
Ahhhhhhhh i installed the deck into my car and i thought everything worked fine i hooked up my subs and everything but when i turn the volume down the subs stay beating and the rca cables only work in the av in slot its driving me crazy PLEASE HELP
  • Anonymous Feb 11, 2008
    do i need a different wire
    Problem Solver:
  • 6 Answers
Be sure to check your gain outputs on your amp it may be the case.
Posted on Feb 05, 2008
Stereo install yukon w amp and subs
Recheck your connections from deck to "non-sub" speakers. Are you using an adapter from deck to vehicle wiring harness OR are all wires individually connected?
Apr 09, 2014 | 2002 GMC Yukon
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
The amp worked fine for about a year then one day the bass would not play through my subs properly sounding like a cd skipping only with the bass i would turn volume down and it would work fine until a...
When you hooked up your amp, did you hook it directly to the head unit so that it didn't come on with the car? Did you find the inline fuse in the amp positive cable? Few things to check..
Jul 13, 2017 | Kenwood KAC-6104D D Class Mono Power...
I have a fairly good sound system in my jeep cherokee, new speakers, deck, new battery, rca cables, and a new box for my subs. But recently i've been dealing with some problems. i've had my amp grounded...
there are really only 2 causes for this.
  1. grounds. Make sure the grounds are clean and tight and all paint and dirt was removed before they were fastened.
  2. Your alternator is starting to go bad.
I would lean toward the grounding problem as you have said you just changed them. Also make sure the grounds are as short as possible.
Dec 24, 2009 | Car Audio & Video
Amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Mar 15, 2009 | Kenwood Car Audio & Video
Deck, Sub and Amp Problems
check for any loose connections at the fuse block or a loose fuse
using an ohm meter would help
check the harness on the back of the radio for loose connection
bad igntion switch, again an ohm meter would help !
what type vehicle ?
Jan 13, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
Panasonic CQ-VD7003U Car DVD Player Logo
82 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
