Question about Lanier 1205 Copier
Lanier LD032c Photocopier The red spanner light is on and the screen is stuck on 'downloading, please wait'. If you could suggest a way to fix this as we have turned the machiene of to reset and it still has not fixed the problem. Please advise as soon as possible Kind Regards Liz elizabeth@connectedhomeloans.com.au
  • elizabeth776 Feb 05, 2008
    LANIER LD032c Photocopier.
    Thank you for the above solution but unfortunately niether suggestions have worked??
    It is still stuck on the "Now Loading" screen.
    Is there anything else i could try?
  • elizabeth776 Feb 14, 2008
    I have since had someone quickly look at the machiene and was told i needed a new hard drive. I have since bought a new hard drive and put it in to the machiene which has made it work, but it only works on the copier function, the printer will not work.
    Is this becuase i have changed the hard drive?
    How can i now fix this? is there software that needs to be downloaded or something??
    Thank you
    Liz
Sc 711 what problem
Posted on Jul 06, 2009
    Scholar:
  • 78 Answers
Try a software reset which involes holding down the * and # (next to the 0) buttons for about 10 seconds until you hear a beap. You should then see "Now loading. Plese wait" and it should start up normally.
Its possible the machine has just locked up. If the above procudure dosen't work power off at the power piont and leave off overnight.
Please advise if any SC codes are present with the spanner for further help.
Posted on Feb 05, 2008
  • Clint Bowden
    Clint Bowden Feb 12, 2008
    If it was myself I would take of the back cover and disconnect the hard drive and turn it on without it connected. If that worked I would reconnect the hard drive and see how it went. Only attempt this if you reasonable technical - otherwise a board has failed. Only work on the machine with the power off!
  • Clint Bowden
    Clint Bowden Feb 15, 2008
    Alright the Hard drive should still allow the print and scan functions to at least show up when you hit the buttons on the control panel.
    When the hard drive is disconnected does it allow access to the print and scan functions?
    There is a format function in service mode and this could work but I would strongly recommended a service agent unless you are very technically minded.
    Now there is also a possibility that a power surge down your network has taken out your print/scan module as well as the hard drive.
Dsc224 color print misalignement
This model is infamous for this. Not a job for those without experience.
Aug 27, 2014 | Ricoh 1224c 1232c Gestetner DSC224 DSC232...
Lanier 5227 scanner error
Eenter in the service mode press yellow key - 107 - red key(stop) keep press for 5 seconds,enter in the SP mode open the front door,turn OFF the main switch,wait 15 seconds close the front door,turn ON the power switch.
Jan 22, 2012 | Lanier Office Equipment & Supplies
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Jammed Photocopier
you need to remove the drum unit out of the machine,and take cotton rag use achohol ..rotate the drum clock wise until you see the label that stuck on it..
good lock
Feb 28, 2009 | Lanier Office Equipment & Supplies
PAPER JAM IN TRANPORT
IF THE PAPER IS LAYING FLAT ON THE TRANSPORT WHEN THE JAM OCCURS, THE PROBLEM MAY BE A DIRTY TRANSPORT BELT SENSOR. A TECHNICIAN IS REQUIRED TO REPAIR THIS, AS IT INVOLVES DISASSEMBLY OF THE IMAGING UNIT.
Dec 22, 2008 | Lanier 1205 Copier
Meter reading
2 ways to check the meter.
press the user tools button on the op panel. on the screen press counter. you can either view the counter on the screen, or press print counter, and it will give you a hard copy.
the 2nd way is to look behind the front cover, probably behind a piece of tape, on the right side, about half way down.
Nov 20, 2008 | Lanier 1205 Copier
375 people viewed this question
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
