Question about Samsung Napster YH-920 MP3 Player
Samsung napster YH920GS/XAA
My friend gave me it because it stops in the beginning with the message "loading library". It doens't turn off. I think he erased the system files and didn't make any backup. Is there a way to fix it?
  • Anonymous Mar 19, 2008
  • Anonymous Jul 13, 2008
My problem is similar, but when i connect the usb cord to the device and then to a pc, the device gets hung up on the bootloader screen. Any suggestions would be welcome!
Posted on May 13, 2008
Dv328aew/xaa runs about 10 seconds then stops with error code hE
Heater Error. Samsung believes only its customer support team is capable of solving the problem. If you go to and enter Dv328aew/xaa, you may find a more practical answer.
Aug 29, 2016 | Samsung WF419AA Front Load Washer / Dryer
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ... > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
Samsung WF350ANR/XAA has an error code FL and door will not lock to start cycle
The FL Code means that the door failed to lock. Turn the machine off and restart the cycle. If this does not clear the error message and the machine does not return to normal, you will need to contact a Samsung repair service.
Jul 25, 2012 | Samsung WF337AA Front Load Washer
I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Dec 31, 2009 | Samsung WF206ANS Front Load Washer
Can't download music from Napster to YH-920
Move all the files to the windows media player. So the songs are listed in the media player. Then connect the device and use the sync option in the media player. There may also be a sync option in napster but I think the windows media player would work better.
May 13, 2009 | Samsung Napster YH-920 MP3 Player
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Got a samsung napster with problem below,wondering if it can be repaired
Jul 10, 2008 | Samsung Napster YH-920 MP3 Player
Samsung YH920GS
System/DATA/PP5000.dat is the special database inside the System directory .
You need to reinstall firmware,
here you can download firmware for your phone:
to Firmware upgrade.
1) Download attached file to your PC
2) Connect MP3 Player to PC with USB cable
3) Excute Recovery Utility (See Instruction Guide)
4) Excute Firmware upgrade
Mar 15, 2008 | Samsung Napster YH-920 MP3 Player
Samsung Napster YH-920 MP3 Player Logo
160 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
