Can I set default printing to black and white for color laser printer?
I am considering buying a Brother MCP-9040 color laserjet multifunction printer. I plan to use the color option infrequently and would like to be able to set the default printing/scanning faxing setting to black and white and change the setting manually when I need to use color in order to save color cartridges. Can this be done? Easily?
  • 2 more comments
  • anita_nolan Feb 05, 2008
    I know that I can change the print option every time I print - but I don't want to have to remember to do that - particularly when I'm printing from the internet. I just want to be able to change the default settings for the printer so that everytime I use that printer it prints in black and white unless I specifically change the print option in the printer dialogue box to color..
  • jangolder Jan 22, 2009
    I cannot find out how to set my lexmark x125 printer to default to black and white.
  • marcyk Feb 24, 2009
    I have the same problem but I am using a Mac OS X 10.5. Anyone know how to set on the Mac? Thanks,
  • Anonymous May 13, 2009
    Does TecniklyNuts know how to read??? Mac OS X is not windows.
    Scholar:
  • 103 Answers
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 05, 2008
  • 73 Answers
To change default on printer, Start, (Control Panel, Printers) or just plain (Printers) if it shows on your computer that way, right click the printer, left click Properties, Printing Preferences, Color tab, Print in Grayscale, Print in Black Only Grayscale.
If you have one photo or document that you want to print in color, you don't have to keep going through the long procedure. Instead of clicking the print button at the top, do File Print, Preferences and change it quickly just for that one document that you have. It will not change the default setting of Black or Grayscale.
You can make that the default printer by Start, (Control Panel, Printers) or just plain (Printers) if it shows on your computer that way, right click the printer, Set as Default Printer.
Posted on Aug 28, 2008
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
My HP 3052 won't print color. Prints in black and white fine but no color! Thanks
The LaserJet 3052 is a Black and White only model. It does not PRINT in color. It will SCAN in color.
Jun 21, 2010 | LaserJet 3052 All-In-One Printer
Dell color laserjet 5110cn will not print any color documents.
This could be a hardware problem, but likely it is a driver or default configuration problem.
If this printer is hooked up to the network and you print to it through a print server, the default print setup or driver could be incorrect or misconfigured.
Whether it is hooked to a network or not, check to be sure the driver is correct under the printer's properties.
Also check to see if it's default settings are set for it to print only in black and white. Both can be done through the printer's properites.
Mar 17, 2010 | Dell 5110cn Laser Printer
Dell color laserjet 5110 cn will not print color documents. This network printer was printing color fine until yesterday mid-day when it started printing in black & white only. I tested by printing a...
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software.
The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
Mar 17, 2010 | Dell 5100cn Laser Printer
Why does the Samsung clp-510 color laser printer keeps defaulting to black and white print out when printing color images?
Well one thing you should do is when your printing something out before you print make sue that you have selected color not black and white because most printers have a default setting to use black and white. Also make sure that you have color ink available to print.
Apr 09, 2009 | Samsung CLP-510 Laser Printer
Printing in color
You can't. This is a Black and White laser printer. If you want to print in color, you need to buy a Color Laser printer.
Feb 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
I need to know if this printer, MFC-8660DN is a color printer. If so what cartridge do I buy. I can find nothing stating it is color.
This printer is a multifunction black and white laser printer. It takes the Brother TN580 cartridge. There are many sources for this cartridge, just google it.
Aug 05, 2008 | Brother Office Equipment & Supplies
7,465 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
