Question about Philips 42PF7320A 42 in. Plasma HDTV
Phillips plasma its a 42in plasma tv. the tv turns on works fine for 20 minites then shuts of and blinks 5times with a red led and power suplly clicks
  • Robert weinelt Feb 05, 2008
    i swapped the board into an identical tv and that tv works fine. is there any other advice you can offer?
I had the same problem....moved to a new home, and the TV power button would turn green, then red, then off. It 'fixed' itself when I pushed the "menu" button in on top of the TV.
Posted on Aug 21, 2008
I have a 42inch aslo, at first part of the screen would go blank and if you tapped on the tv it would come back on. Now it is flashing a red ligth seven times. and will not turn on
Posted on Jul 29, 2008
Don't buy any product from phillips!!!!!!!
Posted on Jul 25, 2008
I'm having similar issues and was wondering if you had any success changing out the logic board. We replaced the small signal board already, but no luck.
Posted on Jun 11, 2008
  • 113 Answers
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Posted on Feb 05, 2008
  • Joshua Dobbins Feb 05, 2008
    The only other thing that could really cause what you are talking about is the logic board. If you are looking at the tv it is up under the main board on the bottom middle. This board could be causing shutdown and is connected to Y sustain which is also connected to the powersupply board. This board taking a dive can take the whole tv down. Not as bad on price around 300 dollars it is subbing to part number 996500038481 if you can swap that out like you did the power supply though you might save some headaches.
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
50" Philips Plasma 50pfp5332D/37 won't turn on
I have a 42in vizio led with about the same problem i replaced a 75 cent chip # u33 on computer board problem fixed.
Sep 25, 2012 | Philips 50PFP5332 50" 1366 x 768 Plasma...
My hitachi plasma tv model: p55t551 every time i
turn tv on the red power light comes on then goes off again
Jun 27, 2010 | Televison & Video
My 42in panasonic plasma viera blinks 10 times and will not turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 02, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
Turning on my phillips tv the power button is blinking red
Plasma? Your power supply has bad capacitors. 3300uf most likely. This is a common problem on some Philips plasma TVs. Power board is located top center of the TV with the rear access panel removed. look toward the lower left portion of the board. If you notice any capacitors (they look like little plastic wrapped cans) with swollen tops or leaking dark fluid from the top of them, replace them. Myself, I always step up the voltage rating... ex: 3300uf, 10v -> 3300uf, 16v.
Mar 15, 2010 | Televison & Video
Tv wont turn on and automatically shuts down
I'm having the same issues with my phillips flat panel. I downloaded the firmware update from phillips and that helped...but only once. I'm back to the same issue this morning. But you might try this download...it may work for you.
Sep 06, 2009 | Philips 50PFP5332D 50 in. Plasma...
Blinking red led light when I plug in the tv then it turns right
Phillips purchases the main circuit board from Samsung, and it has a problem with capacitors failing. The failed capacitors can be easily identified as the top will no longer be flat, but will have bulged up.
If you have a local TV repair shop they can help you.
Jul 26, 2009 | Philips 42PF7220A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
271 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
