Question about Toshiba 50H72 50" Rear Projection Television
SHARP T.V. not responding to remote, but remote isn't broken
I know the remote isn't working because it lights up and also works on other sharp t.v.'s.  I also tried a universal remote and that didn't work.  The sensor on the front of the t.v. is probably broken what can I do?
It happened one hour ago. Mine is toshiba projection 52" TV. I replaced the batteries for two remote controls I've used for this TV but both don't turn on the unit while the console can turn on/off and control the tv properly. I suspect same thing about some kind of sensor but hopefully not. I'll leave the tv unplugged overnight and see.
  • Toshiba Master
  • 5,138 Answers
Here are the Toshiba codes for universal remote- 000,048,049,072,073,105,109,118,160,162,190,&241 try these codes and see if this works.ThankYou for using FixYa and Have a Nice day.
Posted on Feb 05, 2008
6ya staff
SOURCE:
My Sharp 55" Smart TV doesnt respond with remote
Try a different remote such as one for your bluray player to isolate if tv or remote
Nov 02, 2017 | Sharp Televison & Video
I need a manual for a Sharp 19NV88BK television. The volume is stuck in the stereo mode, cannot lower it manually or with the remote. TV responds to remote except the volume.
Remove wall plug to the television.
Sit down, drink half cup of tea.
Put new batteries in the remote.
Drink other half cup of tea.
Put wall plug back in as all the power internally should be dissipated.
Try remote again.
Remote still not working? Clean buttons with wet cloth and dish liquid, turn remote upside down, wait 5 minutes. Clean buttons with damp clean cloth.
New Remote
http://www.sharpremotes.com/index.cfm?page=4
Manuals are here
Sharp Corporation Sharp Global
Nov 29, 2016 | Sharp Televison & Video
Sharp aquos remote not working
the polarity of the batteries in case the monkeyed with them.
Remove the batteries from the remote, unplug the Power to the TV, reinstall remote batteries taking care the polarity of the batteries in case the kids monkeyed with them and then plug the power cord back into the TV.
If that fails, take the remote to the store and and see if it works on their Sharp TV like yours. If that fails contact Sharp support for a replacement. (1.800.BE.SHARP)
Dec 17, 2013 | Televison & Video
I have a new sharp aquos tv LC 60LE633U. Remote is broken but have a universal Phillips remote anyone know the code ? Help please
Hello
Three digit universal remote codes for Sharp tV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sharp Televison & Video
Remote Stopped Working
It is possible the IR sensor is bad. Most of the time if it is a remote issue, the light on the remote will not light up. Does the remote that came with tv still control any functions? I would try the remote that came with the tv, and then go from there, but it sounds like your IR sensor has gone out on you.
Mar 31, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp lcd five yr old monitor wont turn on
If the button on the tv doesn't work, and the remote does, its a contact thats broken. If the remote and the button don't work, it can mean that the dead. The only real way to know if its really broken is to call you local, certified by Sharp, repairman to diagnose the problem.
Dec 20, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
A Sharp flat-panel that doesn't read inputs and responds slowly.
I have the same tv. and the same problem.
I am able fix other LCD problems.
But this one is a bit harder.
I will try changing all the capacitor and let you know if this works
Jul 03, 2008 | Sharp LD-26SH1U 26 in. LCD Television
My grandmother needs the code her GE universal remote to operate her Sharp TV. Thanks
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
Possible codes, seeing as each tv is different you will have to try until one works, the third list is for models bought before August 2002
found all of the below info at http://www.jascoproducts.com/support/universal-Remote-codes.asp
SHARP .... 0079 0123 0063 0020 0004
....... 0009 0226 0266 0006 0095 0122
SHARP
591, 604, 729, 671, 679, 684, 809
Sharp
004, 006, 012, 029, 095, 111, 112, 113, 122, 171, 173
Let me know if you have any questions, please don't forget to rate my solution after you fix the problem
Apr 25, 2008 | Televison & Video
Same thing happened to my Sharp 29 inch. Stopped responding to original remote the first time, but a universal worked fine. Eventually it stopped responding too all universal remotes. The remotes are good, they work with my VCR, DVD player, and Receiver. It's a nice TV, but having to get up and adjust the volume every commercial break got old a few decades ago! If anyone has any other possible solutions aside from getting the sensor replaced...would be great to hear it.
Oct 29, 2007 | Sharp 32C-240 32" TV
Toshiba 50H72 50" Rear Projection Television Logo
178 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
