Mitsubishi WD-52725 52". Rear Projection HDTV Logo
Posted on Jan 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Want to replace caps which board is the DM board?
Want to replace caps, which board is the DM board? already have the tv disassembled . its the timer light flashing issue! Mits WD52725
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Jan 07, 2010
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
190382
Points
1925
Once you take the shield assembly off, you will see a board, I believe it is the DM Board board. There are four Capacitors grouped together probably rated at 35v 1000 mfd, 105 degree. They should be replaced with 35v 680mfd,105 degree Capacitors. Now once that is done, there is another board under that one. This is the Format Board. It also has 4 Capacitors that should also be replaced. They are the same value as the first Board and should be replaced with the same 35v 680mfd, 105 degree Capacitors.
Please note the Flex connectors at the bottom of the DM and Format Boards. They may not be available from Mitsubishi any more so be gentle with them and make sure the are installed properly when reinstalling the Boards back into the chassis. There is one other Board you should look at. The Power Supply Board is the board on the back of the chassis and also has a number of Capacitors that fail. Most all of the Capacitors that fail through out this chassis will have bulging tops. So any you see bulging, you should replace whether they are on the DM, Format , or Power Supply.
I hope this helps,
Skyassoc
  • james humphrey
    james humphrey Jan 23, 2014
    i looked at the dm board and the caps all look fine none of them are bulging
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
2answers
We have a rear projection Mitsubishi TV, Model # WS-55511.We had a power outage last night and when the power came on this morning, we cannot get the TV 'ON'.There is however the TIMER light on the...
Thats a very common problem caused by weak caps on the DM board when power is lost they drain and then cannot recharge when the power is restored the WS55511 DM repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the caps and the cd with instructions.
1helpful
Mitsubishi WS-65511 has flashing timer light but will not turn on.
I used to have a WS55909 and had this problem. The light is supposed to blink for one minute while the DM (digital module) boots up after a power loss. If the light continues to blink indefinitely, there is a problem with that board. The DM power supplies are known to have faulty capacitors on these models and will need to be replaced. If I remember correctly, there are (7) 1000uf 25v capacitors and they should be desoldered from the board and replaced with 35v ones. Note that my TV model already had 35v caps but changing them solved the problem: electrolytic capacitors have a much shorter life than other components.
The DM is on the left side and is where ANT-DTV and the IR repeaters plug in. The power supply is the board above the main DM board inside the DM case.
If this sounds too technical for you, get a new TV because a repair guy will charge you more than the TV is worth. In other words you could get a (30-46") LCD TV for the same price.
6helpful
Power timer lamp flashing, tv will not power up
The caps on the DM and power boards need replacement. Yo can get the repair kit called the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which has the caps and the CD with instructions.
The timer button on my tv keeps flashing and wont allow me to turn the tv on.. what do i do
Replace the capacitors on the DM and the Power boards. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com the kit contains the upgraded caps for both boards and the CD with repair instructions
Televisions timer light is blinking tv will not
Thats usually caused by failed capacitors on the DM board. You can get the DM repair kit for most mitsubishi models from www.tvrepairworld.com the kits contain the Caps and the CD with instructions
1helpful
2answers
I noticed that there was a green blinking light on the front pannel of my WD-62525 TV. The TV would not power up. The cable sound was OK..I disconnected the power Cord for the TV from the wall. Waited 10...
The DM pwb is about 300.00 but it sounds like the caps have failed in the DM which is a 35.00 kit which includes the caps and detailed instructions. Its called the V26 DLP DM repair kit. You can get it at www.tvrepairworld.com
1helpful
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
2answers
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
