Question about Motorola Mobility SLVR L7 Cellular Phone
ITunes on my phone
Ok, so...once or twice i removed my slvr with doing properly and now whenever I plug it in, I get a message box saying that the device can't be read. Plz help I miss my music!!!!!!
    Brigadier General:
  • 7,752 Answers
Well get the firmware reflash on the phone and next time when u connect it to the pc via usb cable you will remove it the correct way.....take the phone to a mobile service center and have them reflash it for a small fee.
Posted on Feb 08, 2008
I am now using my moms old i phone 3g an it says disabled an none remembers the password and my i tunes says i cant restore unless i know it
plug the iphone to your computer (make sure you have itunes installed in your computer) turn the iphone off once plugged. Once its turned off, press the power button and the home button at the same time, hold it for around 10 seconds but continue holding the home button. on your computer (itunes) it should show up a message detecting the device (iphone) just press ok and it will bring you to your itunes home screen--from there CLICK "RESTORE" and that will enable your iphone again :)
Aug 21, 2011 | Apple iPhone Smartphone
Hey. I was plugged my iPhone into a wall charger. As soon as I plugged it into the dock it vibrated twice then suddenly stopped charging. Then again it vibrated... But only once then it went off....
have you tried holding the power button and the home button on the front together? Anything?
if that doesnt work power up your comp with most recent itunes on it and hold the home button down on the iphone and keep held down while plugging to comp and keep held until a message appears on itunes saying a phone has been detected in recovery mode, then restore your iphone as new.
if your phone is over heating then its a safety issue, see if your still in your years warrenty and if you are give apple a ring they should help you out under your limited warrenty
Jan 14, 2011 | Apple iPhone Smartphone
All of a sudden itunes will not recognize my iphone when I open it up. When can I do to fix problem? I have uninstalled and install itunes twice.
Hello. Did you take a look at the genreal setting of the iTunes?? You can configure if you want itunes to be loaded automatically whenever you plug you iPhone
Dec 28, 2010 | Apple iPhone4 4G iPhone 4
How to install theme in motorola slvr l7
To install themes on your l7 you will first have to download skinman and p2k drivers try the latest one (you can search for these softwares in google) In your phone change the default USB settings as data & fax connection then connect your phone to a usb port to which you had never conected your phone before then you will get a message that a new hardware is found select to "install now" then select "Install from a specific location" tick the "include this location in search" click "briowse" and select the p2k drivers folder that you had downloaded. For example "D:\Motorola System\p2kdrivers_2.9" Then click "next". It will install your phone. Then again you will get the same kind of message do the same for all until it says your phone has been installed and is ready for use. Now you have done half of the job. Now run Skinman the file list will be loaded. select install.You will get a message just select ok then browse and find the theme that you want to install then select open the theme will start installing. once you have added the desired number of themes select restart phone. now you are done.
Mar 23, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Moto L7
como desbloquearmotorolaL7 , perdi su codigo de seguridad
Aug 12, 2008 | Motorola Mobility SLVR L7 Cellular Phone
I dropped my slvr and now the screen is white - can I retsore the screen?
to do a master reset blind press the red button a few times to make sure you are at the home screen. now press the center button once, press 8 then 5 press up twice then the center button once now enter your 6 digit security code and then press the center button twice. that should do a master reset on your phone. If that doesn't work then your screen is destroyed. If you don't want to spent money on a new phone you can always use the voice dialing button on the right side of the phone located right under the charging terminal. press it once then give a command (EX. "Call Joe smith") the phone should confirm the command, then say yes or no
Aug 06, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Songs skipping!!!
my phone sound is low please ask what possible to sound are hi
Apr 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola slzr iTunes
Disconnect the USB cable from your Motorola phone featuring iTunes, Wait 10 seconds & Reconnect the USB cable to the phone (it will confirm the connection with a tone). Again Wait 10 seconds, then open iSync and try syncing again. If the issue continues, turn your Motorola phone featuring iTunes off and then back on. Then open iSync and try syncing again.
Oct 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Downloading problem
I am pretty sure you need to use Itunes software, because Windows Media Player is not a compatible software Itunes. So I suggest you use these instructions: 1. Install Itunes on you computer via the disk that came with your phone or via internet on the Itunes website. 2. Transfer all of your music to Itunes( it is pretty easy) when Itunes is installed a window should pop up stating if you would like Itunes to import all music. ( IF NO WINDOW POPS UP THEN DO IT THIS WAY) 2b.While Itunes is open follow this procedure click File Scroll to Import or Add Folder to Library Select folder Click OK Repeat till all music upload this will take a bit longer , but you can now be able to use your phone.
Aug 15, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola SLVR won't sync with iTunes. HELP.
hopefully it is converted to .mp3 then try again
Aug 13, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
