Question about ViewSonic VA1703wb Monitor
1440*900 resolution is not coming
Hi
i have installed the Software from the CD which comes with ViewSonic Monitor but the recomended resolution is not coming.. i am unable to get the recomended resolution..
Plese help.
how i can get the required resolution
  • Chris Lemke May 11, 2010
    Please post monitor type and also your computers hardware information... at present I couldn't even tell you if your video card supports the resolution you are trying to achieve.
    President:
  • 2,351 Answers
Your going to love this. Open control panel, open display. Click the settings tab. Click Advanced. Click the Monitor tab. Remove the check mark from "hide modes". Click the drop down menu & set it to 75 hertz. Click Apply & than ok. You are now back to the Settings window. At Screen resolution move the slide bar to more. Pick what you want. Again click Apply & than ok. Bingo there you are! Have a nice day.
please vote...
Posted on Feb 05, 2008
Hi
I am using Fedora14, in this i am not able to use 1440x900 resolution.
In monitor preference it shows unknown
Posted on Mar 29, 2011
That sounds great, but what do you do when the "hide modes" is not chedked and no other option but 60 Hertz is there?
Posted on Mar 06, 2008
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
Ihave viewsonic lcd monitor va1616w. Display card is NvidiaGEForce2 integrated GPU. The resoultion is not coming correctly
Maximum resolution on this monitor is 1366x768. Check your color depth( 16 bit, 24 bit, etc) and do not set the resolution greater or you will get unpredictable results.
Brock
Sep 16, 2010 | ViewSonic VA1616w 15 inch LCD Monitor
Out of range message seen after installed new software and reboot
The monitor will display out of range message because the PC video resolution is too high for the monitor to display, the new software may have changed or corrupt the video seting, try booting up in safe mode (hit f8 while computer booting up) and set the video resolution to 640 x 480, then reboot in regular mode, then reset the resolution to the native resolution of this monitor which is 1280x1024@60Hz.
Mar 24, 2010 | ViewSonic VA703B LCD Monitor
My monitor keeps say out of range, at first I thought it was a problem with driver but I did everything Viewsonic said to do, I think it is my monitor, is there anything I can do?
that is either resolution problem or animation picture problem your motherboard is with in built dispay card which do not support to high resolution .for that you have to install AGP card into AGP slot then you can see better video .if you want to see low resolution normal computer then restart the computer and press F8 and keep pressed untill options will come then select last good known configuration then enter problem will be solved
Mar 09, 2010 | ViewSonic VG2030wm LCD Monitor
Out of range
Your windows video settings are for a monitor that has more capability (eg more pixels/finer resolution, higher refresh rate, more colour bits than the current screen can handle so it's spit the dummy.
Run your computer in safe mode (I believe that uses basic video driver) and set the video display options to a very low level, then re-start your computer again in normal mode, and set the options to the native resolution, refresh rate etc of the monitor. These should be listed in the specs that would come in the box with it (may be resolution: 1,680x1,050)
Sep 13, 2009 | ViewSonic VX2235wm LCD Monitor
Can't set 1680x1050 resolution on viewsonic monitor
I found the solution for my problem.
Initially I thought it's a monitor problem and was trying to find the drivers for it.
The problems is not with my monitor but with the video adapter I use.
My video adapter has a intel chipset (Mobile Intel(R) 965 Express Chipset Family). Apparently the driver that I was using was quite old.
The only thing I had to do is:
1. Download the latest video adapter driver
2. Uninstall the current video adapter driver
3. Restart the system (Windows XP)
4. Install the new driver.
5. Restart the system.
May 19, 2009 | ViewSonic VA2026w Monitor
My ViewSonic computer monitor keeps displaying a Vga Not Support Message upon booting then the message Out Of Range comes up on a completely dark screen. Need Help
It sounds like the computer is trying to use a resolution that the monitor cannot handle. Boot into safe mode by pressing the f8 key during boot up and select safe mode. Once booted, right click on the desktop and select properties. In settings lower the resolution by moving the bar to the left and reboot.
I would move it all the way down, you can then move it up a step at a time once you are in normal mode again.
Hope this helps
May 02, 2009 | ViewSonic VA721 17" LCD Monitor
Screen resolution - Viewsonic N3735w
Buy a monitor that wil accept your video card size  resolutions?
Jan 11, 2009 | ViewSonic N3735W 37 in. LCD TV
My monitor is not allowing me to display a resolution
If you have the origional CD that came with the monitor, use that to re-install the drivers for the monitor back onto the pc. Then go to viewsonic and look for updates. Do a "system restore" and put the system back to the condition prior to doing all of this. I will re store your files to what they were but "system restore" will not roll back "windows updates". This will tell you if it is something you did or windows did.
Aug 16, 2007 | ViewSonic VA1703wb Monitor
Blue Resolution Box
To turn off the reminder, use the buttons on the front of the monitor to do the following:- Press #1. Use down arrow to highlight Setup Menu and press #2. Use down arrow to highlight Resolution Notice and press #2. Select Disable and Exit.
Aug 13, 2007 | ViewSonic VX2235wm LCD Monitor
ViewSonic VA1703wb Monitor Logo
271 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
